Xuv snowplow blade
   / Xuv snowplow blade #11
That's about right. My dealer got me in the $3500.00 range for the same at essentially his cost, but even with a very sharp pencil it will be about in the same price range. These are just very nice plows and it costs a lot to make them and BOSS is not that big a company so profit margin may be pretty high. I would love a BOSS power V plow and feel it to be the ultimate UTV plow out there, but for our sporadic snows I am going this time with the JD PowerTach plow for my Gator. It has a bit more snappy hydraulics and will do what I need for about $1K less coin. From what I have heard, the Power V plows fine (great) in straight blade setup also; pretty close to the BOSS straight blade.
John M
   / Xuv snowplow blade #12
Since I got my Kubota, I am giving my son up in Idaho my Big Bear. He doesn't get a lot of deep snow, has 5 acres, and has a 400 foot driveway that gets drifted over.
Will the old Yamaha Big Bear 350 push a plow? Just wondering if it's worth the investment in a winch AND a plow. Don't know much about snowplowing, it's 92 degrees here in Ca. right now. Could the winch and plow be put on a newer machine in the future?
Re ryerman I would say no on plowing with the 350. Just too small for that kind of workout in a snowbelt. 500 or bigger.
   / Xuv snowplow blade #14
I have the Deer V-plow (manual). The V configuration works great in deep heavy snow for a first pass. But in the straight configuration the bump in the middle makes it a little harder to for the snow to slide across the blade if the snow is wet. Doesn't seem to make any difference with powder.
Changing blade positions is a pain. I'd get one of the hydraulic plows if I were starting over and had the money.
   / Xuv snowplow blade #15
Given the number of times I swing the blades, I'd have trouble justifying the $1800 or so premium for the hydraulic Boss over the Deere v-plow.
i figure I can convert my Deere for about $800, have the design largely drawn up in CAD, but it's progressing up the project priority list very well, since there's a master bathroom to complete, miscellaneous trim, lighting, etc. in the kitchen that SWMBO is demanding, and a hydraulic thumb for the excavator all ahead of it.
Before this winter I hope to fab and install separate spring-loaded pins in each of the six locating holes to speed the re-anling process. I have just completed the design and material selection process and need to build/test the prototype. If you are interested, I'll share pictures, drawings, etc. when I get it done. Installation would be via 2 small welds connecting a short length of 1/2" sch 40 pipe to the top pin rail.
   / Xuv snowplow blade #16
Spring loaded pins sounds great -- dealing with the pins while wearing gloves is the worst part. Please do post or send photos/dwgs when you're done. I can sort of picture it in my mind except for how to captivate the pins inside the springs.
   / Xuv snowplow blade #17
I plowed with my Big Bear 350. The lift arm on mine worked great. Never hooked it to a winch. Anything under 8" or so is no problem. My road/driveway is around 800 ft and I plowed it with no problem..That 3 footer we got last winter would have been a different story though. My neighbor's Sportsman 700 couldn't touch it.
   / Xuv snowplow blade #18
You're right about angle changes..it is a pain with gloves on. Trying to find the pin ones it get's buried in snow and ice is an even bigger adventure. I have power angle now. Haven't tried it in snow yet, but my hopes are high.
   / Xuv snowplow blade #19
I was looking at the eagle plow for UTv'S - Thet are considerably cheaper - does anyone have experience with one of these? Would they be any good for average/light snow? Where I live we average about 20-24" of snow a year (Though last year we had 80") -Mike
   / Xuv snowplow blade #20
I just got a 72" Eagle v-plow for my Gator 620i. Haven't plowed with it yet but I am impressed with the quality. It is built heavier than I expected. My drive might be 300 feet and I'm sure it will do everything I want. I just got the winch mount made and am ready to test it out before doing the final shaping and painting.
We don't get enough snow here in southern Ohio for me to justify $1800 for the Deere blade let alone the more expensive ones. The Eagle v-plow cost me $720 shipped for everything. If I need a little down force I can fab some mounts for struts like some of the other blades use.
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
2017 KENWORTH T800 TRI AXLE SLEEPER TRUCK (A57880)
2017 KENWORTH T800...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
1111-A (A54756)
1111-A (A54756)
John Deere 4820 Forklift (A57453)
John Deere 4820...
