Tractor stuck in field, rite of passage? :)
   / Tractor stuck in field, rite of passage? :) #1
shiver
I decided to hook up the bush hog today on the back of the MF35 and test it out in the fields to see whether or not it was a wise purchase.
It was going great, I was chewing up and spitting out all the 5' long grass, saplings and such.
I've taken this route a couple times the few days, just because I was kind of
getting used to how the tractor (my first) would handle the property.
On the way out of the same path I took in and then it happened, my tires were buried half-way. The ground was more water than mud in that location, even though it's a high point.
After about an hour of trying to get her out by putting large rocks, gravel
and long grass to try to both give a footing and support to the tires, I finally gave up, she was sitting on her frame.
So, I took the eventual walk, right down to my neighbor who loves and collects Belarus tractors, if he could do me a favour :) He was more than
willing and we got it out.
There really isn't a point to this story beyond, I think I'm going to need to get myself a winch.
   / Tractor stuck in field, rite of passage? :) #2
How about Water Wings?:laughing:
   / Tractor stuck in field, rite of passage? :) #4
Yep,just one more pass or I should make it can get you every time :(
Welcome to Muddy Mower club..you paid your dues by the sounds. ;)
   / Tractor stuck in field, rite of passage? :) #5
It's going to happen again, be warned. I've been stuck pretty good more than once and still certain forbidden parts of the farm call me "come drive here, it'll be ok..."
   / Tractor stuck in field, rite of passage? :) #6
Hint:
Staying out of wet and muddy areas will keep you from getting stuck, and will make for nicer looking areas without deep tracks in them. :)
Then again, if mudding is what you like to do, then get the winch. :D
   / Tractor stuck in field, rite of passage? :) #7
We don't have any wet spots here. rain has been very scarce. I can hardly see the paint on the tiller or tractor for the dust.Jy.
   / Tractor stuck in field, rite of passage? :) #8
Make sure to stay on good terms with the neighbor and all will be well.
   / Tractor stuck in field, rite of passage? :) #10
Just add some floats. Then you can go through the water and even take yout tractor fishing! :laughing::thumbsup:
PT Cattle Feeder (A56469)
PT Cattle Feeder...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
UNUSED RAYTREE RMA42' HYD AUGER (A57193)
UNUSED RAYTREE...
250 GALLON DIESEL FUEL TANK (A57192)
250 GALLON DIESEL...
2023 Can-Am Defender XT (A56469)
2023 Can-Am...
