Buying Advice High hour tractor
/ High hour tractor #1
mossbackfarm
Oregon
JD5300
Hi there
First time poster, long time lurker...after 10 years of ranching, it's finally coming together to get a tractor, mostly for mowing and feeding haylage bales (1100lb) to the cattle. And, of course, whatever else I find to do (fencing, hauling, etc)
Our tractor broker has put me on to a JD5300, 4wd, with a loader that has a quick release bucket and pallet forks. Ideally, a bale spear would work with some of that. He's asking $13,500
The concern I have is the tractor has 4000 hours. Besides that, it's got good rubber, a couple of minor dings...all around pretty good. But, with that kind of time on it, I'm wondering if it's over the hill, and will be worth waiting out a better or more reliable deal. I'm not the best grease monkey out there, so while I'd be able to do some work on it, I don't want to end up knowing my local JD service center *that* well...
Anyone have any thoughts on this? Thanks!
Rich
/ High hour tractor #2
For a tractor that's been taken care of, 4,000 hours isn't much at all. You should get better than 8,000 out of one without too much in the way of headaches.
/ High hour tractor #3
I had an old Massey 85 that ran just fine when I got rid of it. Of course I did a valve job at 10,000 hours.
/ High hour tractor #5
Agree on the hours, we have tractors that are used all the time and were made in the 50's with nothing more than normal maintenance.
/ High hour tractor #6
Hi there
Rich
Any service records available for that tractor?
It could have seen hard 4000 hours or an easy 4000--you need to find out how it was used by the previous owner(s).
Since you'll be relying on that tractor to do real work around your place, you need to check it out very thoroughly.
Leaks? What kind? How much leakage?
Smoke? What kind? White could be coolant leaking in the cylinders. Blue is oil burning. Black could be a fuel system problem.
Run OK in all gears?
3pt hydraulics OK? Best to check this out with an implement. Does the 3pt hold the implement up OK without slowly leaking down? Does the float setting work OK?
FEL OK?
That JD5300 was made between 1992-97. 13-18 years. 222 to 307 hours/year average. Pretty light usage actually.
My info tells me that the price is reasonable. If it checks out after inspection, I'd go for it.
/ High hour tractor #7
Hi there
Seems awfully expensive to me - I'd expect a price around half that for something with 4000 hours, or a tractor with half the hours for that price. I bought my 2000-hour Kubota L4200GST w/ loader and Woods 9000 backhoe for roughly that amount.
JayC
/ High hour tractor #8
How Funny that you mention $13,500 - exactly what I paid for my 1440 hour 4610:)
Whats tractorhouse say? The "high" hours on mine put it around $5k less than anything on there at the time so I went for it - no regrets one year and 300 hours later.
The only other tractor experience I have is the FILS Fiat/Hesston 566 which has around 12,000 hours on it. Guess when I compared working on it over the years vs my cars I did not think anything of getting a high hour tractor - knowing they are so much easier to work on.
Good luck Bro:thumbsup:
/ High hour tractor #9
I wouldn't be surprised to see Deere getting a higher used price and resale value than other brands. The reason is because they're built to last a long time and you get excellent support from dealers on parts. It's why you see so many older Deeres out there still in service. Seems like evrytime I'm in the market for a used tractor, there's no used Deere equipment I can afford, but I know they're worth a premuim over other brands.
/ High hour tractor
Thanks everyone....good info that gave me a lot to think about. Tractorhouse shows it right in the low end of the price range, which is promising. I'm going to arrange a visit to kick the tires and see it in person next week. Then, I'd better start getting the money together:eek:
Rich
/ High hour tractor #11
I wouldn't be surprised to see Deere getting a higher used price and resale value than other brands. The reason is because they're built to last a long time and you get excellent support from dealers on parts. It's why you see so many older Deeres out there still in service. Seems like every time I'm in the market for a used tractor, there's no used Deere equipment I can afford, but I know they're worth a premium over other brands.
The high resale value on John Deere makes some of the other models a better value to me personally. I don't view John Deere overall superior to all the other brands based on my experience; good, yes, superior, no.
/ High hour tractor #13
Really?? I think the Deere model comparable to my M-7040 is heavier built and offers some really sweet options not offered by Kubota. I really like the way you can raise/lower the 3 pt from the back of the tractor.
Don't get me wrong, my 7040 is a good tractor and I got it cheap, leaving me money in my bank account, but I don't deny the Deere is a heftier built machine. More steel.
/ High hour tractor #14
Read my post again as I was very careful to say "overall" and not model for model as I accept there will be differences such as on the M7040 and others.
Again, I personally do not consider John Deere "as a whole" to manufacture equipment superior to all others. I own one and I may very well may own another, so I am not one of those brand loyalists or brand bashers.
/ High hour tractor #15
I understand what you mean. I'm not a brand loyalist either, as some are here to Ford trucks, Deere tractors, etc. It amazes me how people will just trash the same brands literally thousands of times over & over on this site & other sites. The "My neighbors GMC blew its' engine 5 times", or the " Kubota sucks" BS. :rolleyes:
/ High hour tractor #16
I grew up around mechanics/farmers and such. None of them go that route either. My wife and I own two Toyotas and a GMC. We have owned Chevy, Ford, Oldsmobile, VW, Nissan also. One of my brothers is a mechanic and owns Chevy trucks, Honda cars, two Ford trucks, a Toyota truck as well as two Mazda trucks that I can think of and he has owned just about everything.
As to tractors we own three Kubotas, three Fords, one Case tractor and a Case backhoe, one John Deere and a Massey Ferguson.
I have also owned the following brands of motorcycle Honda, Bultaco, Triumph, Ossa, Kawasaki, Suzuki, Yamaha and Harley.
Over the years, I have had a couple of bad machines, but that can happen with any manufacturer.
/ High hour tractor #17
As far as raising and lowering the 3 pt. hitch from the back I can do that with my old 1985 Kubota B7100HST-E tractor. Maybe he just needs to buy an older tractor. Lol Now get in an uproar, just kidding about the older tractor. LOL Pete :D
2021 John Deere 333G Skid Steer (A63109)
2021 John Deere...
Arrowquip Heeler Portable Corral (A64047)
Arrowquip Heeler...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2022 Meridian 1375 Auger (A63116)
2022 Meridian 1375...
SHOP MADE 36' T/A GOOSENECK SHOWER/EYE WASHTRAILER (A63569)
SHOP MADE 36' T/A...
