Is this worth it? (MF35 w/ loader, Bush-hog + blade)
   / Is this worth it? (MF35 w/ loader, Bush-hog + blade) #11
I bought her this weekend and drove her home today :)
She's going to need work, but we'll get there :)
Thanks all.
That is great, Keep us posted on your progress. Pictures would be nice :) Ken Sweet
   / Is this worth it? (MF35 w/ loader, Bush-hog + blade) #12
Hi Shiver, if it's an FE 35, the main frame and engine should be gold painted, but over here it's not unusual to see them overpainted in grey ( as the grey was a later tractor ). One certain point is the number of bolts around the rear axle stub. Look inside the rear wings at the end of the axle where it meets the the brake drum plate, if there are 12 bolts then it's an FE35, If there is 6 bolts, it's an MF35.
Thanks 033614. The MF serial number plate lists it as an FE-35, I'll check the # of bolts, but I believe that when Massey / Ferguson merged, it was basically a repaint of MF red/grey of the FE-35 line.
I'll go check the bolts.
I just realized this last night. I think there's more truth to the repainting of
the FE-35 :)
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
1831 (A51247)
1831 (A51247)
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
