Jay4200
- Joined
- Nov 23, 2005
- Messages
- 2,054
- Location
- Hudson/Weare, NH
- Tractor
- L4200GST w/ LA680 & BX2200D w/ LA211
Our central Texas property has a 1000-foot road made with "road base" which is basically a layer of crushed limestone. When we bought the place a year ago, it was a really nice, flat, smooth dirt road. After two houses were built, all the heavy truck traffic packed down the fine material in the ruts so these bigger rocks are sticking up all over, and the road has acquired a fairly high center. Some of the rocks stick up 3 or 4 inches, very unhealthy for the tires on my wife's car.
I just finished re-doing 1100 feet of road this summer. Re-graded/re-crowned - pulled all the rocks, than spread 6" of hardpack. I spent many days pulling rocks out of the road and the grounds (~1/2 acre). I graded with my FEL, and had my wife on the ground (wielding a hoe and shovel) as my rock picker. Whenever she hit something she couldn't budge, I'd swing by and pop it with my backhoe. Give the wife a pickaxe and let her go to town for a week popping out anything she thinks is sticking up too high.
Up here, I have to worry about sucking rocks into my snowblower, and the rocks you leave will eventually grow (NH's biggest crop) and come through the surface. I disagree with our friend from Canada - I pull out everything bigger than a golf ball if I can see it. HOWEVER, you guys down there don't have freeze/thaw conditions, so your rocks won't grow.
I wouldn't buy anything new for the tractor. I'd scrape the road lightly using my FEL, and use it to pop out anything that was sticking up more than an inch or so. Between that and the wife's pickaxe, you'll be all set in short order. Then I'd hit it with a landscape rake. If the road surface is really hard, which it might be, the rake won't do much. Your road looks reasonably crowned though, so all you need is a surface dressing. I'd probably bring in a few loads of material to make it purdy, but it doesn't look like that is necessary for your road, unless you can't break the surface with your rake. You'd need roughly 100 yards of material to give it a 2-3" top coat. If the road is rutted or improperly crowned, then you'll probably need a blade to re-crown, although a rake works fine for that too, provided the surface is soft enough.
JayC
