Snowblower Front end mount used on hardpack driveway
   / Front end mount used on hardpack driveway #1
NHTC40D
New Hampshire
Kubota L5740 with LA854 FEL
Front end mount snowblower used on hardpack driveway
I am interested in purchasing a front end mount snowblower for a L5740. I am being told by the dealer that I may not be happy since my driveway is not paved, it is a hardpack surface and about 500' long. I am looking for feedback from others who use a front blower on similar surfaces and points to consider.
   / Front end mount used on hardpack driveway #2
Ya, I can add to that. He's wrong. A snowblower can be used effectively on ANY surface.
Why did he tell you that.??
I guess he feels that risk of ingesting material and breaking pins. But I figure you can always angle it up a bit.
   / Front end mount used on hardpack driveway #4
While it is true that using a snowblower on a gravel driveway has more risk of ingesting gravel into the machine, it remains an everyday occurrence. Most folks simply run shoes on the blower and leave an inch or two of snow on the ground. There is no practical difference between front and rear mounted blowers on this issue.
Mike
   / Front end mount used on hardpack driveway #5
snow blower saga begins;
for a Grand L5740.
it is a hardpacked surface and about 500' long.
The use of a front mounted snow blower for the Grand L 5740
like any other large tractor with a front mounted implement has many
sides or problematic issues depending upon many variables and a greater purchase cost.
plusses and minuses:
All weather cab-plus
High end seating and suspension- plus
The grand L 5740 will require a high output alternator to aid in night vision when snow blowing using the front or rear mount-plus
greater purchase cost -minus
added requirements for hydraulic or electric controls for front mount operation-minus
You have dual remotes installed and can use them with no modifications for a rear blower-plus
a. poor line of sight vision with front mounted snowblower implement-minus
(you are unable to see what is directly in front of you other than the nose of the tractor and the snow blower body)
a1. the open cross auger can be flooded more easily with a front or rear mount blower
if driven too fast= plus-minus
b. adding a remote camera will improve this only if it is boxed and mounted to avoid snow build up +-
c. the front mounted blower requires an underbody mounting frame which will reduce ground clearance and it will get stuck(been there done that) minus
d. the midpoint power take off is 2000 rpm which is reduced and reversed for the use of a front mounted implement through the snow blower gear box-minus
e. power loss through multiple gear reduction-minus
e1. no limited slip PTO friction disc clutch for the front mount snow blower( shear pins)
(much less of an issue with a rear mount blower as it is using 540 rpm only to power the impeller and auger chain drive gearbox)
f. adding pneumatic caster wheels to aid in steering and to avoid digging in the driveway for the front or rear mount-plus
g. having tires loaded with windsheild washer fluid and buying tire chains(which is something you should do for either mounting anyway) plus
Rear mount blower installation:
a. the operator is directly above and behind the snowblower - plus.
b. dual remotes make the use of a hydraulic spout and chute control a plus(other wise you would need to open and close the rear window to chage thge chute direction (I do not know if the rear window can be opened on this model).
c. the suspension seat makes it much easier and less stressfull to operate in reverse as you are only traveling at 1-3 miles per hour
which is 88 to 254 feet per minute(dependent upon snow load and visibility-+.
d. the rear mount only requires the use of the 540 rpm rear P.T.O. and three point hitch for attachment (plus the PTO shaft).
You can add casters to the rear mount to make it easier to turn when in float, and follow the driveway contour with out doing a lot of digging,
and by adding pneumatic casters you can limit the blowers ability to dig in by mounting them slightly below the scraper of the rear blower and setting the needle valve under the seat closed(if it has the needle valve to lock implements in place).
adding a rear view camera will be easier as you can simply place the monitor almost anywhere to the right side of the seat to reduce the neck strain (I am unsure if the seat swivels or you can get a seat that swivels).
The thing is you are traveling at a very slow pace and the rear view camera will aid in snow clearing and visibilty.
The purchase of a rear mount blower:
Purchasing a rear mount snow blower has more advantages than disadvantages due to its inherent design efficiencies.
a. 540 R.P.M. directly from the tractor to the snow blowers gear box which also provides reduced speed for the cross auger.
b. high ground clearance by lifting the implement.
c. easier removal of snow drifts when the rear mount snow blower is raised with little if any spillage.
d. a rear mount snow blower no wider than the tractor tread width uses the machines horse power to its ultimate advantage with a rear blower
as it can be operated at full power engine power for the 540 R.P.M setting load to remove snow. A rear mount blower will be easier to remove snow
banks and melted packed snow and ice.
e. the rear PTO creates less of an engine load as well versus the mid point P.T.O. system
f. the initial purchase cost is less than a front mount blower set up.
g. The rear mounted snow blower will outlast your tractor and can be moved from machine to machine.
My personal preference for a snow blower are the Pronovost line of snow blowers as they are built for canadian winters
and I can personally say they are a better snow blower in my opinion as I have spent a lot of time examining them,
and how well they are built as they are built for canadain winters.
for the end user.
   / Front end mount used on hardpack driveway #6
I manage a snow thrower test site here in the UP of Michigan for a worldwide manufacturer of snow throwers.
Normally we only test walk behinds and small rider mounted throwers.
2 years ago we had a large JD tractor (honestly cannot remember the model) with about a 60 inch JD thrower on the front.
Our test site is 40 acres and the surfaces range from new pavement and concrete , grass, gravel and uneven fields.
All of the throwers, including the large JD Tracto mount have skid shoes on the sides to allow the bottom of the thrower to sit higher than the actual ground.
All of the throwers worked well on all surfaces.
All of the throwers have shear pins which will break ....hopefully before any gearboxes or shafts
we test all throwers to 150 to 200 hours of continuous use
It's hard to argue with that kind of testing. Thank you for your insights.
   / Front end mount used on hardpack driveway #8
Both will throw rocks and junk equally. The front is just easier on your neck and back;) Here's my old rear blower and the new front blower..... Really no difference in the 2.
   / Front end mount used on hardpack driveway #9
One thing I did not see mentioned is that with a bigger tractor (and heavier loader to go with it), you might have problems with it digging in a bit when "floating" due to the weight of the loader?
but perhaps you are removing the loader and just using front mounted blower? Not sure if the weight would cause it to dig in or not...
In any case, you can always increase the shoe size on the skids to help with that or add casters to help.
I have a 48" front mounted snowblower on my Gravely rider and it was too heavy for the small skids, so I made new ones that are 4" wide so I don't dig into the gravel. Before I did that, even with the skids adjusted to give me the most clearance, I moved alot of gravel into the edge of the lawn. My wife and I are both happier now with the larger skids.
Lots of options for front mounted blowers, good luck!
   / Front end mount used on hardpack driveway #10
I use a front mounted snow blower on my 500' hardpack driveway and prefer it to clearing snow with a plow. Like others, I adjust the skids to keep it from digging up the driveway and it works fine. After a couple snows, you sort of get a frozen base that holds everything together and you can adjust the skids so the blower scrapes the surface without risk of digging in.
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51244)
UNUSED TOPCAT...
CATERPILLAR 320GC EXCAVATOR (A51242)
CATERPILLAR 320GC...
2023 CATERPILLAR 307.5 EXCAVATOR (A51242)
2023 CATERPILLAR...
John Deere No. 5 Sickle Bar Mower (A50515)
John Deere No. 5...
