Lack of Power
/ Lack of Power #1
loopyl
Member
Vermont
I have a 4 year old Kubota L4400 with 330 hours. Over the last few weeks I have noticed a large drop in power when going up any incline. I have to shift to a low gear or the tractor will come to a complete stop. I cleaned the air filter, that didn't help. I replaced the air filters, that didn't help. I cleaned the fuel filter, which did have some gunk on it, that didn't help. I suppose I can replace the filter but it looks quite good and I suspect that won't make a difference. Is there anything else it could be? Can it be within the engine itself.? I should also note that in the spring, after researching it, I started to use #2 heating oil in the tractor, without any problems. Could that have something to do with it? Any help would be appreciated.
/ Lack of Power #2
At 330 hours there shouldnt be anything wrong with in the engine.
If It were me, I'd drain the fuel system completely, make sure there is no gunk in the lines, REPLACE the fuel filter, and put sone fresh fuel in and give it a try. If that don't help, it is possible that your injectors may be plugged up a bit.
/ Lack of Power #4
I would try some Lucas injector cleaner. Just add to your fuel. You can buy it at auto parts stores.I would also put in a NEW fuel filter. Good luck.
/ Lack of Power #5
When was the last fuel filter replaced? If it were mine and the fuel filter wasn't replaced recently I would change it and not add anything else and see what changes. At 330 hours your injectors should be fine unless you never load the engine. Do you have any abnormal smoke, white smoke at start up, blue while operating?
/ Lack of Power #6
replace fuel filter, replace fuel filter, replace fuel filter... had similar problem, traced it to fuel filter ..water absorption restricts flow.;)
/ Lack of Power
I replaced the fuel filter and drained the lines and put new fuel in, no help. I spoke with the dealer who said that maybe the clutch is slipping. I noticed the clutch pedal was tight and did not have any slack when pushed down. I loosened the rod to the factor specs. It is a bit better but still not right, so I am thinking it does have something to do with the clutch. Are there any other adjustments if it is "slipping"?
The exhaust is fine, clear smoke.
He also mentioned using an additive- Power Service, but why would I suddenly need that now?
/ Lack of Power #8
i run power service all year long.
/ Lack of Power #9
does the engine bog when you go up a hill or does the engine maintain RPM and the tractor just slows????
If the engine bogs, the clutch is fine.
If the engine continues reving like on level ground, but the tractor slows considerably, then the clutch would be slipping.
How many hours do you have???
/ Lack of Power #10
My tractor has a valve that is opened to exhaust air in the lines following filter replacement, etc..... if somehow it got opened accidentally, or left open, which I did once, it seemed to loose power but still ran.... might be worth a double check. The valve should be closed after air is exhausted from fuel lines.
/ Lack of Power
When I have cleaned and then replaced the fuel filter I use that valve to bleed the line, it is closed.
The RPM's are maintained, I will double check, so maybe the clutch is the problem.
2005 John Deere 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
