slowing down hydraulics
/ slowing down hydraulics #1
rbushmaster
Member
what are the options to slow down a log lift?
its a seperate control valve
i know you can get a flow control valve for about a $100
is there other ways?
ive read somewhere about putting a washer with small diameter hole between hose and fitting is this ok?
do you put 1 washer on the inlet side or a washer in both the up and down stroke lines
1/2" male on one end of hose 3/8 flare on cylinder side
/ slowing down hydraulics #2
A restricting washer would be a hit or miss, then change out to find the speed you want. IMO
A flow control valve would be adjustable.
Look at those at Surplus Center (sponsor here).
http://www.surpluscenter.com/sort.asp?catname=hydraulic&keyword=HAFC
There are flow control valves as well as restrictor valves. Also, having 1/4" hoses will slow it down some, but I use the Parker fc. $20 range, not $100
/ slowing down hydraulics #3
How about using the valve in the feather mode. Just push or pull the lever a little bit. You do not have to use full lever throw to activate the log lift.
If nothing else works for you, then you can use a divider valve. This one is a 70/30 split. If installed before the second valve, the 70 percent of the fluid would go to tank, and the 30 percent would go to the lift valve. Reduced flow, reduced speed.
https://www.surpluscenter.com/item.asp?item=9-5416&catname=hydraulic
/ slowing down hydraulics #4
KISS (keep it simple stupid) method applies here. All you need is a needle valve on one side of the cylider that is moving to fast then you can adjust the speed precisely to what suits you. You can go the washer/hole route, but as stated it is hit or miss as to the speed you will end up with. But whatever you do, NEVER put a restrictor on the IN side of the valve, only on the work ports.
thanks,
i ended up taking a 3/8 bolt , rounding corners off head drilling a 3/32 hole thru and tack weld in to hose end made it much more manageable could of went even smaller with the hole though
/ slowing down hydraulics #6
I've drill and tapped the inside the fitting then put in a brass set screw with the hole like you did that way you can change or adjust it if needed.
/ slowing down hydraulics #7
You can buy these restrictor orifices that normally give you pretty reasonable control. This one is 0.030" or about 1/3 the size you drilled. They typically cost about $4.95 each from my New Holland dealer.
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2020 KUBOTA RTV-X1140 UTV (A63276)
2020 KUBOTA...
1990 Chevrolet P6000 Command Center Step Van (A64556)
1990 Chevrolet...
2014 Ford Explorer AWD SUV (A64557)
2014 Ford Explorer...
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
