Bent Bucket Fix???
/ Bent Bucket Fix??? #1
Denwa
Blaine WA
Kubota B20
Yo,
I'm Jonesing for a tooth bar for my FEL, but the PO left it with a slightly bent lower lip. With the bucket resting on the floor the center of the bucket lip sticks up about 1.5", perhaps 2". Have not actually measured the deflection yet.
So, two questions:
1. Is this enough of a bend to keep a tooth bar from fitting?
2. What ingenious way has anyone come up with to straighten the lower lip of a FEL bucket?
I can envision going to HF and getting one of those hydraulic pulling rams,
setting out a stout unbendable object such as a girder or a big log, placing a couple of jack stand on that and resting the bucket on the jack stands. Then attaching the puller to the girder and the center of the bent lip on the bucket and pulling it straight.
This should work. Any better way or comments on my concept would be appreciated. I don't have a shop press, but I do have a few floor jacks and bottle jacks.
Regards,
Dennis
/ Bent Bucket Fix??? #2
If its a slow bow take a couple of 4x4 stack them on the center and lift the front wheels of the tractor off the ground with the bucket resting only on the lip and see if it deflects back to were it was.
If that dosn't work use a girder running along under the lip tie ends of bucked down to girder (chain around bucket and girder) and use a hydraulic jack between the beam and lip to bend it back up in to place.
the pulling rams aren't very strong you
/ Bent Bucket Fix??? #3
Any idea how it was bent up?
That would help to know for a suggestion how to fix.
Does the bucket have an edge blade welded on? Or is it without a blade?
With the bucket on the ground, might put a post in the bucket over the bend (rise) and under a heavy tree limb or house/barn beam. Then curl the bucket to hopefully return the bend to straight (er). :)
Or if you need the excuse to buy the press...that should be a good one. :D
/ Bent Bucket Fix??? #4
Straightened mine with the wood splitter, blocked up each end of the bucket and used a block under the wedge to push the bucket past being straight till the bucket was straight when I released the wood splitter.
/ Bent Bucket Fix??? #5
GOOD ONE!!!!!!
I never though of flipping my log splitter vertical
side note they work good to brake beads on tires too!
tom
/ Bent Bucket Fix??? #7
Weld a thick angle iron across the top of the bucket, then pound in progressively longer vertical 2x4's standing in the bucket between the upper and lower edges. They will push the lower lip down. Will be easier if you couple it with chaining the bucket edge down and use curl to add extra force. You always do need to go past straight to get it to stay straight. Shouldn't be too hard to fix. The extra beef of the tooth bar will help keep it from happening again.
/ Bent Bucket Fix??? #8
I bent mine the opposite way by pushing spruce trees over. I got it mostly straightened out (enough to take the tooth bar, anyway) by curling the bucket and pushing on a sturdy tree.
BOB
/ Bent Bucket Fix??? #9
If I understand, the edge is bent upward, correct? Bucket looks like a frown rather than the more common smile???
If that's the case, wedge the edge under something immovable with the bottom of the bucket on the ground. A stump works well. Curl the bucket back. The curl function will almost certainly have enough power to bend the edge. Go a little at a time. If you overbend it can be harder to correct.
A bend in that direction is usually the result of pushing against a tree or similar, with the bucket curled.
.... If that dosn't work use a girder running along under the lip tie ends of bucked down to girder (chain around bucket and girder) and use a hydraulic jack between the beam and lip to bend it back up in to place.
Tom,
Thanks, however, bucket lip is bent UP. But your above idea in reverse would be easy and work well. Put the girder/beam etc INSIDE the top edge of the bucket and use the hydraulic jack to force the lower lip back down into position.
THANKS! Good'n.
Dennis
Been,
No idea how it got bent, came that way. Likely pushing on something with the bucket curled. Yes it does have a blade welded on. Had not thought of using the curl function to bend it back. I think one would have a problem controlling how much bending was going on there. Might make it worse in the opposite direction. Could use an observer for better results I suppose.
YES, good excuse to buy a 20 ton press!
Thanks,
Dennis
Mr. Milk,
WINNER!!! Why couldn't I have thought of that? I've already got the wood splitter, which come to think of it would make a fair 27 ton press, according to the specs.
Thanks! I had faith you guys would pull a rabbit for me. Great list.
Dennis
GOOD ONE!!!!!!
tom
Tom,
I sense a new thread here ;' >
"Alternative uses for a wood splitter".
Good idea.
Dennis
Heat and a big hammer!:thumbsup::thumbsup:
Egon,
Son in law still has my "heat" tanks. Used the big hammer on my draw bar,
and judging by how much whacking I had to do on that smallish thing, bending the bucket might exceed my whackabilitys.
Dennis
FT,
The angle iron bracing is a good idea, but I think I'd rather use a bottle jack than do all that pounding.
D
BXp,
Thanks, will consider using the curl in future. Finding something strong enough to take that force would be the major issue.
Dennis
/ Bent Bucket Fix??? #17
Mr. Milk,
Dennis
Forgot to add that I put a piece of railroad tie across the foot of the splitter, then put blocks under the ends of the bucket.
/ Bent Bucket Fix??? #18
You can also use a hydraulic bottle jack in the middle of the bucket lip and run a chain over the top of it. Attach the chain ends to the bucket lips out at the sides...weld temporarily or bolt it.
2008 FORD F350 SUPER DUTY DUALLY PICKUP TRUCK (A59909)
2008 FORD F350...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
NEW HOLLAND T4.75 POWERSTAR TRACTOR (A62130)
NEW HOLLAND T4.75...
2017 Ford F-250 (A55973)
2017 Ford F-250...
2015 International WorkStar 7500 T/A Dump Truck (A61568)
2015 International...
