2007 Ranger 700EFI HD Speedometer
/ 2007 Ranger 700EFI HD Speedometer #1
Avondale
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
Hi
Anyone have any experience with fixing a speedometer on a 2007 Polaris Ranger 700 EFI (HD). Mine no longer indicates speed but rest of display works as does 4x4. Any hints on where to start looking (i.e. sensor location, test points and values, circuit wiring diagram). Thank You and much appreciation for whatever help is available.
/ 2007 Ranger 700EFI HD Speedometer #2
Hi
Here's some info on your problem your experienceing w/ your Ranger.
Hope it helps !
http://www.prcforum.com/viewtopic.php?p=225132&sid=5d14a6bdcea94046dd32f2cd9b9e3682
Boone
Thank You
I had seen this post so I checked my 4x4 and it works.
I am wondering which wire to check for input signal as there is a wire bundle leaving the back of the display via a multi-pin plug and enters a wire harness which vanishes under the dash works. If I knew where the sensor was located, I could determine the color code, might even be able to test with DVM. I can check against some representitive volt sigs from speedo systems on my other ATVs.
Thanks again, much appreciate your efforts on my behalf.
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
2022 EZ-GO ELITE...
Single Cylinder Hydraulic Grapple Bucket Mini Skid Steer Attachment (A64553)
Single Cylinder...
UNUSED SDLANCH SDLC1220-12'X12' HIGH END CARPORT (A65055)
UNUSED SDLANCH...
2006 Heil DOT 406 9,500 Gallon Comp T/A Fuel Tanker Trailer (A64194)
2006 Heil DOT 406...
