RTV 500 Trans Drain Plug. What size is it?
   / RTV 500 Trans Drain Plug. What size is it? #1
gobraphil
Member
It isbigger than a 22MM ...
1 1/16 did the trick. MAke sure your drain pan is big enough..!!
   / RTV 500 Trans Drain Plug. What size is it? #3
Just curious. I have a RTV 900 and I recently completed my 50 hr. service which did not require draining the transmission. All the fasteners, plugs, etc. I encountered were metric. Was the 1 1/16 socket/wrench an approximate fit? That's just shy of 27mm by my calculations, so do you think the plug was 26mm?
Steve
fit pretty good to me... It was all i had too..
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
Krause Dominator 4850-18ft (A56435)
Krause Dominator...
2020 MACK P164T (A58214)
2020 MACK P164T...
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A57880)
2018 KAUFMAN 44 FT...
2019 GALYEAN...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
