Hydraulic control valve
/ Hydraulic control valve #1
Gary Sweat
I apologize in advance if this has been covered before but I didn't see it brought up exactly.
I bought the Bailey joystick control valve 220-910 to put on the FEL I just finished building. The valve did not come with any paper showing the port routing so I figured I could blow air through the valve, move the joystick and see where the air was going. Three of the ports have the raised letters of "P", "T" and "N". I called Bailey and they told me what they mean. P=Pump, T=Tank and N=Power beyond (which is currently plugged).
Here is my question: When I put air to the "P" port and move the joystick I do not get any air out of any port. I reversed the air to the T port, move the joystick and air flows to the correct discharge port so air is moving from (as I understand) the discharge port for that ram to the tank port. Do these type of valves require a certain amount of pressure before the inlet port opens up? I called Bailey and told them this and they promptly sent me another valve in 2 days but it is doing exactly the same thing. I don't want to install this valve and dead lock the pump.
/ Hydraulic control valve #2
Then you most likely have a 'Closed Center valve', the reason you do not get air out through the work port could be that the load check valve is blocking (lightly spring loaded??)
You are probably blowing backwards....return into workport
se above about a spring loaded check valve
What type of system do you have?? Open or Closed Center??
fixed displacement pump=99.9% open center system (0.1% closed center load sensing with dump valve)
/ Hydraulic control valve #3
Most likely, the plug at the power beyond port have to be removed.....to make an Open Center valve
/ Hydraulic control valve #4
This link has a link to an instruction sheet for the valve (or one very similar). Bailey web site said that all their valves have load check valves installed. Your air pressure is probably not enough to open the check valve.
Prince Hydraulic Loader Valve - RD522GCGA5A4B6
Thanks guys. It may be that I did not put enough air pressure into the valve since it appears these have a check valve. I put about 40 lbs of pressure on the valve. I will try 135 lbs and see if it opens.
The tractor is a Yanmar 1900 and from what I have read it needs an open center valve. This control valve passes straight through when it is in the center position from "P" to "T" ports. I will be breaking the pressure line from the pump and routing into the "P" port. The tractor pump currently has a pressure line from the pump back to the 3pt and I assume it dumps into the transmission until the 3pt is activated. I thought the valve would work by routing the line out from the "T" port back into the other end of the cut pressure line since the valve passes straight through from "P" to "T" in the center position and when the joystick is moved it opens the discharge port from the ram to the "T" port. The loader kits I have looked at all say to break the pump pressure line and route back out of the other side of the valve to the same line. I don't have a need to power anything at the same time the loader is operating so I didn't think the power beyond would be needed. It has the option to add it. My thinking on the power beyond may be completely wrong on how it works.
/ Hydraulic control valve #6
If you look at the drqwing in the link I think it depicts your situation where the 2nd control valve and cylinder represents your 3 point hitch. Pump supply to inlet (P) on loader valve. Outlet (T) should tee into the outlet side of rear hitch and the high pressure supply to the hitch should come from the power beyond port on the loader valve. So, if you cut the high pressure/pump supply to the 3 point hitch. Connect the one end to the loader (P) port and the other to the power beyond port.
http://www.princehyd.com/Portals/0/products/valves/RD5000InstS.pdf
/ Hydraulic control valve #7
The load check on a valve only works to keep the cyl from moving while shifting the levers. There are other valves to maintain a loaded bucket and lift arms.
If you are not using the PB plug, the OC plug will block that port, and allow the supply fluid to flow out the return port, plus the fluid from the cylinders.
Option B is the open center plug.
Which plug do you have in the valve now?
You might need to find out the return port pressure limits. Call Baileys for this.
Maximum tank port pressure on the RD-5000 hyd valve is 500 psi. Do not use the return port to feed hyd pressure to another valve.
Thanks for clearing this up, I think I understand it now. I will need to get the power beyond sleeve for the valve and connect the other side of the pressure line to it so it will feed the 3pt hitch. I guess with this valve, I will also need to route the Tank outlet on the valve to the return line on the tractor with a "T" fitting in order for the cylinders to return oil to the transmission?? The valve has a plug in the power beyond port right now and there is a hole between the tank and power beyond ports connecting them together. I assume that when I put the power beyond sleeve in, it will block the cross connect hole between the tank and power beyond ports?
Sorry for asking so many questions but I don't want to take the chance of shearing the pump shaft if I get it wrong. From what I have read, the pump does not have a relief valve and the output flows through the pto until you move the pto lever and then the pressure is routed to the pto with the excess pressure vented to the transmission.
/ Hydraulic control valve #9
Just to make sure you are understanding me, the pump pressure hose goes to the IN port, and the FEl valve PB port now connects to the 3pt hose.
The Pb sleeve essentially blocks the cylinders expended fluid from the downstream fluid. The expended fluid ,with no pressure, leaves the valve via the return port and goes to tank.
I understand the in and out hookups now and again thanks for the help. The only issue I am trying to figure out now is the tank "T" port. I don't have a tank exactly. The pump pressure line goes directly to the pto and it sits on top of the transmission and I assume it dumps into the transmission via a hole between the two. The suction line comes out of the bottom of the transmission to the pump. There is no actual return line from the pto to the transmission. So, looking at the diagram from the Prince set up, I'm not sure where to run the "T" port to. Can I run it to the suction line or will that cause a vacuum when the control valve is in the neutral position and maybe cause creeping through the valve? When using the PB sleeve, do I still need the "T" port or will the cylinder return oil be routed to the PB port and I just plug the "T" port hole?
/ Hydraulic control valve #11
When using a PB equipped valve, You CANNOT plug the T or OUT port as it carries the "waste oil" from the work ports to the tank.
When you say:
I take that it feeds the 3PH, so that is where you would plumb the PB port from the new valve to. Somewhere on you transmission should be a plugged port you could use as a return-to-tank port. What machine do you have?
Here are pictures of the tractor PTO lines and pump. If there's a place on the PTO that I can use for the return line please let me know. Thanks
Here are photos of the valve. If that helps?
Well, I got the valve figured out. This valve returns the cylinder oil to the PB port when the levers are moved. When the PB sleeve is installed all oil goes out this port and the tank port is blocked off. It also passes the pressure oil to this port when the levers are in neutral. So all I have to do is put the PB sleeve in and move the plug to the tank port and hook the PB port back up to the other side of the cut pressure line and everything should work fine. The valve came with the PB port plugged and that was what was confusing me. I didn't realize the hole between the PB and tank ports was making it look like the tank port was where the outflow was going.
Thanks to everyone who helped me on this. I really appreciate it.
/ Hydraulic control valve #15
Do not plug up the tank ports as that is the outlet for the cyl fluid that is expended. A return hose goes to tank/reservoir.
There is no pressure in the valve when in neutral. The fluid just passed through the valve for downstream operations. If no valves is operated, the fluid just makes a continuous loop from pump through the valves, to tank, with no pressure.
Well, I guess I'm back to square one. There is no return line on this tractor to tie into and no place that I can find to add a return line to without drilling a hole in the transmission and I don't think that is a good way to go. Maybe this valve is not going to work on my tractor and I will have to find a different kind. I'll try to find a picture of how the after market loaders hook up and see what type of valve they are using. I do know they say on their valves to cut the pressure line from the pump and route the pump side into the inlet port and run a line from the PB port to the other side of the cut pump line that goes to the 3pt hitch valve. They don't say anything about a tank line so there must be something different about their valves that I don't understand.
/ Hydraulic control valve #17
Every valve has to have an outlet that goes to tank/reservoir, and is stamped T. If the valve does not have a PB port, the expended fluid, from the cyl and the norm flow from the pump flows through the valve and out the return port, and normally goes to the 3pt, and then to tank.. All the fluid ends up in the tank/reservoir. There is a tank return somewhere on the tractor. The return hose could be adapted to go through the filler cap, if necessary.
/ Hydraulic control valve #18
The kits that Ronald sells at Jinma Loader Valve sells do not use PB valves. Search in the Chinese and Yanmar tractor forums. You would need to keep the PB port plugged.
J J, In the photos I posted, the port on the left of the valve is the PB and the right one is the tank port. There is a small hole between the two that connects them together. If I install the PB sleeve it will block the hole between the two ports and I am still stuck with the return line problem since this tractors pressure line goes directly into the 3pt valve which is mounted on top of the transmission and dumps the oil into the transmission via a hole between the two. There is no return line coming out of the 3pt valve that I can tie into. It is my understanding that it can damage the valve if the pump pressure gets into the tank port. Maybe I should go over to the Yanmar forum and ask if anyone can post a photo of how theirs are hooked up to help me understand what I need to do.
Thanks for the help and your patience.
/ Hydraulic control valve #20
You have a choice here, and that is to use the PB port, or not. If you choose to not use the PB port, then install the OC plug in the PB port, and use the T outlet to connect to the rear3pt. No extra hose needed.
If you choose to use the PB port, then you will have to find a way to get the fluid from the T port to tank. Either way will work, as long as the tank port will handle the high pressure. I would call the people you purchased the valve from, and ask then the question. Will the tank port on the new valve withstand high pressure.
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2025 Good Luck Go Cart (A64557)
2025 Good Luck Go...
462001SFL (A64557)
462001SFL (A64557)
2016 Ford F-250 Ext. Cab Pickup Truck (A64556)
2016 Ford F-250...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2018 Tycrop Vector Belt 22ft. VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
