Differential Lock Pedal
/ Differential Lock Pedal #1
RedRock
Texoma
Mahindra 2816 Gear
Is it me or is the pedal used for engaging diff lock kinda "mushy" or non-responsive?(not in terms of engaging, just general position of the pedal)
Is it supposed to feel like a gas pedal or just firm pressure? The operator guide says a spring is supposed to pop it back up when you let off and/or hit the brake. While I'm pretty sure diff lock is engaging properly when I keep my heel on it, I'm not sure its disengaging properly at times. It doesn't seem to travel very far at all down, yet I can lift it to the full 0 position manually.
I just wonder if I have a bad spring or if the pedal just behaves that way. At times it's clearly closer to the 1 than the 0 though it seems disengaged.
/ Differential Lock Pedal #2
Don't know what tractor you have but my 4110's return spring is pretty light, I can barely detect much resistance in my foot when engaging it but it always returns OK. My "gas" pedal has much more resistance. The travel on mine is pretty good though, from it's fully up (disengaged) position to down and definitely engaged is several inches. On rare occasion it has stuck down (engaged) for just a bit but either hitting the brakes or changing gears with the shuttle has popped it back up - have never had to reach down and help it up.
/ Differential Lock Pedal #3
Mine is like you are describing. It works. Just doesn't spring up fast or have much resistance.
I found a differential lock pedal adjustment I can do, just requires removing the rear left wheel. There is a rod that needs to be 178mm. My best test will be to stop by the dealer and check the behavior of other pedals.... if it ever stops raining. :tractor:
/ Differential Lock Pedal #5
Keep us informed. I've had issues with mine and the "local dealer" split my tractor to fix it .... now it is acting up yet again.
Yeah, I went by the dealership, test drove another one and the pedal engaged and disengaged just like you'd expect. I tried mine out again today and basically figured out it's kinda tough to get it to engage in the first place and hardly noticeable when it disengages.
/ Differential Lock Pedal #7
My 2615, basically the same tractor as a 2816, is hard to engage. Usually the tire has to turn a couple to several rotations before it actually engages.
Yep, exactly - I wonder if Mahindra might chime in on this, it's going to cost me quite a bit out of pocket to get a 2 week old tractor back to the dealer. I don't have a truck and trailer big enough to haul it back...it's why I bought new :/
Spoke with a service manager today and I think he may have given me a better understanding of what's going on with this pedal.
He said he looked at the cog for this and the slots are 180 degrees apart...meaning depending on where you are in the rotation when you start to apply pressure to the pedal will determine how soon or how long before it engages. You've basically got 2 spots in the 360 rotation. He also said that lightly tapping with the heel gave better results than constant pressure on the pedal (which I think I can confirm)
So I'll test it again soon but as long it engages and disengages when I need it to (taking into consideration what I know now about how it works) I feel better about the whole thing. It may be a significantly different feel on my tractor versus the one still on the lot, but at least I know it's just different, not malfunctioning.
...and I didn't know what "splitting" a tractor meant until today, and I don't think I'm ready to do that just yet to a 3 week old tractor. :)
/ Differential Lock Pedal #10
Thanks for the update. I will try the tapping method.
/ Differential Lock Pedal #11
What you are describing is normal and proper for a 2615/2816. It's a cog sort of deal, three notches I think. Not s synchro set-up like a gear in the trans. Feels a little disconnected, but it works just fine.
/ Differential Lock Pedal #12
Well went out and bush hogged a few acres this evening with my 2516 and wouldn't you know it the DIFF LOCK worked. It helps to press depress press depress and let off the clutch and then both wheels locked fine.
/ Differential Lock Pedal #13
I have a gc2400 and the Diff pedal is not very firm or positive. It works but it is not a definitive in/out. I was pulling logs on some wet ground and it does it's job so I am ok with it.
On the other hand my forward pedal is very stiff and the rubber boots always come off (I replaced them with non-skid tape directly on the metal).
The worst is the parking brake, that is a true design flaw. Mine clicks out of lock very easily and there are some horror stories n this board about runaway tractors due to this issue.
Otherwise I love my GC
/ Differential Lock Pedal #14
Sorry everyone, I just noticed i was posting in the wrong board.
Mahindra, Massey, Tomato, Tamato....
/ Differential Lock Pedal #15
LOL no problem. I just noticed I clicked Massey instead of Mahindra right before I read your post HAHAHA.
/ Differential Lock Pedal #16
I like the sense of humor, you are welcome in the Mahindra area any time! Almost the same shade of red anyway.
/ Differential Lock Pedal #17
I know the manual, and with talking maybe even to DavesTractor on here I've been told/read not to hold the pedal down while the wheels are turning. I don't understand how the "whatever" will seat into the cog unless it falls into one of the slots, which to me would best be done by holding the pedal down till it falls in.....????
/ Differential Lock Pedal #18
While the rear drive wheel is turning, you have to keep pressure on the pedal until the lock engages, then release. It should take only a few seconds at most.
/ Differential Lock Pedal #19
You are correct, but we recommend that the driver let the wheels stop spinning, then press the diff pedal and hold it as they let the clutch out (or press the forward pedal on an HST), holding it down until it engages. We are trying to avoid a high speed spin type of engagement.
/ Differential Lock Pedal #20
If I become stuck, I will wait till my wheels stop spinning, push down the differential lever with my heel and hold it there as I press on my hst pedal to move the tractor out of trouble. I can feel with my heel as it engages. Once out of trouble, I stop the tractor and then release my heel off the differential lever. I usually use my heel then to nudge the lever up to make sure it's disengaged.:thumbsup: This is easily done with the hst pedals being on the right and the differential lever on the left. Where is the differential lever for you guys with gear tractors with the clutch on the left?
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
