Demoing a CT235 this weekend. Couple of questions. :)
   / Demoing a CT235 this weekend. Couple of questions. :)
Quick update. After being frustrated by the box blade getting hung up on weenie little stumps, I went back over them with a $160 TractorSupply subsoiler and it was like night and day! Just line 'er up, drop the 3pt about 2' back and let it rip...literally. If the tractor stops moving forward, just tug up the 3pt and inch forward at the same time. Probably grind a edge into the front of the subsoiler to cut the bigger roots. Didn't try on anything over 4", but you could probably pull 2 a minute with the thing if they are close to each other.
   / Demoing a CT235 this weekend. Couple of questions. :) #22
Does anyone have the mmm. for the ct225. Just wondering what size it is and how you like it?
   / Demoing a CT235 this weekend. Couple of questions. :) #23
I have a brand new one!
They are 66"s
On the 225 you will be doing most all your cutting in low range.
I am very impressed with the quality of cut they give.
   / Demoing a CT235 this weekend. Couple of questions. :) #24
Thanks for the reply. I saw the mmm on a used ct112 it seemed to be super heavy duty. How come the web site or books don't offer any information on them?
   / Demoing a CT235 this weekend. Couple of questions. :) #25
Bobcats site is lacking in information, in my humble opinion
   / Demoing a CT235 this weekend. Couple of questions. :) #26
If I remember correctly, the CT225, CT230, and CT235 are all the exact same frame and transmission. Only the engine size is different. And as most people say, power makes all the difference.
   / Demoing a CT235 this weekend. Couple of questions. :) #27
on the ct225 which i had the 66" mower stinks! not enough power so you will be in low for sure. Just sold my 225 for that very reason!
QUOTE=farmer10of13;2075212]Does anyone have the mmm. for the ct225. Just wondering what size it is and how you like it?[/QUOTE]
   / Demoing a CT235 this weekend. Couple of questions. :) #28
just tested ct225 and heard the same sound! sounds like grinding in mid to front of the belly of the moter. made me run to john deere, but not crazy about them either! makes me wonder what r we really buying? korean junk or r they all over seas junk?
   / Demoing a CT235 this weekend. Couple of questions. :) #29
Jcims, I think the source of the rattling noise might be the loader. On mine the pins that hold the loader stand arms, or what ever you call them, will rattle at certain rpms of the motor. I think your when you push the clutch it might change the load on the motor to vibrate them. I have heard of guys taking the arms right off if you don't plan to take the loader off if you cannot stand the noise.
I really like my 335 though. No problems with the tractor, just a issue with the dealer once. I was at your stage once deciding between the 235 and 335.
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
2016 INTERNATIONAL PRO STAR TANDEM AXLE DAY CAB (A58017)
2016 INTERNATIONAL...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
2020 DRAGON ESP...
2022 Ram 2500 4x4 Crew Cab Pickup Truck (A55973)
2022 Ram 2500 4x4...
