Tiller Tiller vs. Harrow
/ Tiller vs. Harrow #1
Redgoatea
Gold Member
On the Oregon coast
JD 870
Okay so gardening is not my thing but my mom wants to plant one. The way she does things it's probably going to end up about 1/2 acre.
So can I just use a disc harrow to break up the soil before planting and after harvest or do I need to go with a tiller??
Other than pricing I'm completely clueless on both implements but I'd like to go with something to attach to my JD 870. Any thoughts?
/ Tiller vs. Harrow #2
I have a garden that I use a 4 ft. King Kutter tiller on. It is a great tiller, I think the heaviest among the 3 point tillers, gear drive. I pull it with a Massey GC2300 tractor. My garden is about 2200 sq. ft.
/ Tiller vs. Harrow #3
A half acre garden is 200 feet by 220 feet, give or take. Big undertaking!
Anyhow, a harrow of any kind, disc, spring tooth, spike tooth, etc is for smoothing out, breaking up plowed soil. It isn't really a substitute for plowing.
Here is what I do on garden plots of that approximate size.
First, I use a simple $150 middle buster plow.
I follow up with my field cultivator. $250. It makes an excellent spring tooth harrow. Move/change the tines, it cultivates. Handy.
So, for $400, I have a well tilled garden. The bonus is that both implements are useful at other times. Very useful.
A good tiller begins at $1500. Tilling is it's only purpose. Very convenient.
The choice is yours, really. Glad to respond to any other thoughts you might have. I have a little video link in my signature.
/ Tiller vs. Harrow #4
A disc harrow breaks up the soil quite well. The first time through it will take multiple passes but after the season and in later years it will be a couple passes and done.
The problem is that the disc harrow won't leave the garden ready to plant. Depending on your mom's condition, it will take a lot of work and a long time to rake and level a half acre.
A tiller will make the soil garden-ready, perfectly flat, and well-churned in a jiffy. Mom can just go out and stick the plants or seeds in the ground.
The first time with the rototiller could take two passes given that the Oregon coast is wet enough to grow grass year round.
Then after the season the rototiller will churn all of the plant material back into the soil. A disc harrow tends to stir it up - not a bad result but nowhere near a rototiller.
Money likely is going to be the deciding factor. However, once you have a rototiller there will be many uses found for it. The cost could eventually be recovered by doing other garden plots in the neighboring area.
/ Tiller vs. Harrow #5
A tiller makes the nicest garden IMO.
/ Tiller vs. Harrow #6
The tractor tiller will be the quickest and easiest. The conventional way would be to plow then use a disc harrow to prepare the seedbed. A disc harrow alone will not go deep enough. Ken Sweet
/ Tiller vs. Harrow #7
BP, by your dimensions 200 x 220 = 44,000 sq ft, an acre is 43,560 sq ft. I believe you meant to say that a half-acre garden is 100' x 220' or 22,000 sq ft.:)
/ Tiller vs. Harrow #8
:ashamed::ashamed: ooooops! Thanks jinman. Had my back. Dang stiff typing figers, ah.. fingers.
/ Tiller vs. Harrow #9
I like the way BP does it. IMO a tiller nor a dics can be used alone. It needs to be plowed first.
/ Tiller vs. Harrow #10
This question comes up every month or so.
Of course a tiller, whether the old walk behind or the PTO tillers are wonderful. I wouldn't part with my walk behind for the cleaning up of rows, working in tight areas, etc.
I wouldn't mind a 3 pt/PTO tiller either. If I had $1500 spare laying around. :laughing:
To these frequent inquiries, my replies merely try to point out a very affordable option that very often gets over looked.
/ Tiller vs. Harrow
Well thanks for the great advice guys. I'll look into all of your suggestions. Mom has been pushing for a disc harrow but I've been trying to tell her I don't think it sill do the job. She's pushing 70 so the easier I can make it for her the better.
I've seen a couple of rototillers on sale lately $850 for a 4'. So I'll investigate that a little more but I'm also definitely going to look into BP's economical options as well. :)7
/ Tiller vs. Harrow #12
I went through this a few months ago. I chose a Deere 647 tiller and have been very happy. VERY easy much more so than the walk behind I rented every year.
/ Tiller vs. Harrow #13
Although probably no substitute for a plough, I find that a few passes with the boxblade with the teeth fully extended tears up the top few inches quite nicely. (I have a single bottom plough but haven't yet learned how to set it up).
/ Tiller vs. Harrow #14
In that $850 range, sounds like chinese to me? Be careful at that price for a 48. Ken Sweet
/ Tiller vs. Harrow #16
I must be the exception... I had a 5' tiller for years and sold it two weeks after I got my disc harrow. That thing covers some ground in a hurry! Tillers are SLOW! I can make a couple passes and still catch the game!
If it your first time breaking the land, a plow first would be ideal, every year after the disc alone will do fine.
/ Tiller vs. Harrow #17
I can agree with that scenario. Ken Sweet
/ Tiller vs. Harrow
Yes it will be the first time that soils been disturbed. I'm thinking definitely a plow to start with. The area was used for many years to strip branches from trees before they were fed into the saw mill so they put down some baseball sized rock for the equipment to drive on.
/ Tiller vs. Harrow #19
I would recomend a Deere 647 or 655 tiller for your tractor, whichever it takes to cover your tracks. I would make sure these smaller tillers have a slip clutch on the driveline and is adjusted correctly. These tillers will work about 6 to 7 inches deep in one pass. Two passes yields great results and you are ready to plant. Tillers are ideal for gardens as you can back up to the fence and start tilling to depth before you move. Disks need to travel several feet to approach the full depth. A good disk harrow that will till dep enough will cost about the same as the tiller. A cheap lightweight disk will not till deep enough for a garden without many many passes.
I wouldn't be too scared about rocks with a forward rotation tiller, it will climb over them and for the most part leave them on the surface to remove. Been there done that. No one wants to hit rocks but it doesn't seem to damage the tiller or the blades, they seem to stay sharp after hitting many rocks. Some the size of bowling balls.
/ Tiller vs. Harrow #20
....ya know.....so much is going to depend on your soil, and what is there now. I have a 2 bottom plow, a ripper, a box blade, a 5' box frame disc, and a 5' tiller. I have tilled new ground without any prior plowing....and I have plowed first and used ripper or box blade rippers first...and then followed with the disc and then tiller. So much depends on the vegetation and soil types. Mostly....for my sandy loam.....I can just lower the tiller and start tilling. One pass and I'm ready to plant. But sometimes.......I have lots of roots and such and it takes a few passes to clean up the land to prepare for the tiller.....then too, sometimes I have stumps and/or rocks.
Like so many things......the answer to this question is: It Depends. :laughing:
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
New Holland TS6030 (A64119)
New Holland TS6030...
2025 MB27 27in Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 MB27 27in...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2017 Ford F-250 Reading Service Truck (A61573)
2017 Ford F-250...
