Loader Piece of hyd level sightglass in trans case of L2800 HST
   / Piece of hyd level sightglass in trans case of L2800 HST #1
Motractr
Kubota l4330
Part of the plastic sightglass is in my hyd case. I replaced with a new one because I noticed severe leaking from that spot. I don't know how long it's been in there- probably 3/4" dia. by 1/4" long (whatever in metric). I refilled hyd fluid. Am I okay to use tractor with piece floating around in there? I am out of hyd fluid. It's a holiday weekend and I need this tractor. I am too far from anywhere to get hyd fluid in order to drain system to find the piece. Shame on Kubota for this plastic design on the sightglass. The tractor only has 300 hrs on it. The "glass" must have been overtightened by dealer or manufacturer. Please help... I need seat time!
   / Piece of hyd level sightglass in trans case of L2800 HST #2
I am afraid to give a recommendation on this one. On one hand, it may have been floating around in there for 300 hours with no ill effect and it that is true then why worry about it for the short term and flush it out when you have more fluid and time. On the other hand, if it is a recent addition to the fluid resevoir it just might clog somewhere that cause a restriction or even makes itself more difficult to remove.
I don't know how to recommend other than to say if I were you and really thought it had been there for a while, I would be tempted to go ahead and work, but I would be super **** about noises and behavior of the tractor and hydraulics and ready to shut it down at the first "weirdness".
Thanks. I'll let you know what happens.
   / Piece of hyd level sightglass in trans case of L2800 HST #4
As JR said.
I for one would use tractor only really needed,for now its one piece could break into more smaller pieces and start moving around in system.
   / Piece of hyd level sightglass in trans case of L2800 HST #5
I'd drain the current fluid into clean containers, with an eye towards reusing it once I found the plastic piece .... ;)
Thanks for the replies. I bush hogged a couple hours and it seems to be okay except power steering is jerky. I parked and am going to replace hyd filters and all hyd oil ASAP this week. Will keep you posted....
   / Piece of hyd level sightglass in trans case of L2800 HST #7
I wouldn't worry too much about a piece of plastic. The suction screen should keep the broken piece in the sump. It may not come out durring a draining of the resivoir anyway.
   / Piece of hyd level sightglass in trans case of L2800 HST #8
Sounds like you might have a leak in your return hose,you did state you have 300hr.s on tractor.Check out link below:
http://www.tractorbynet.com/forums/kubota-owning-operating/122787-l3400-hydraulic-leak.html
Minor problem common to some L2800/3400 BOTA'S.
This has nothing to do with site glass question,just a response regarding your "jerky pwr stg."
Boone
Boone, thanks for the link. Big help.
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
2019 CHEVROLET SILVERADO 11FT FLATBED (A57880)
2019 CHEVROLET...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
