Power Beyond
/ Power Beyond #1
Gstan30117
Kabota 4700
I have a Kabota 4700 w\ a Bush Hog Loader. The loader takes its power from two ports on the side of the transmission. One pressure and one return. I want to run a hose from the PB fitting on my loader control valve to a simple up down valve to raise and lower a no till seed drill. Can I instal a Y fitting in the loader return line to attach the new valves return?
Thanks
/ Power Beyond #2
To Gstan30117
I have L2250 Kubota that I put Power beyond in 15 years ago and all works fine so I must have got it right. Mine has a flat screw on the block for the hydraulics that has a little note that means READ THE BOOK. I now have a 4 spool valve to install so I need to remove my single spool valve. I would check with your local Kubota dealer with they are cooperative type.
Craig Clayton
/ Power Beyond #3
You should be able to Y or Tee the return hose to the existing return.port
/ Power Beyond #4
Thanks
Short answer is yes. That is the only line you may Tee into. The PB port from the FEL valve will go to the IN of the new valve, the PB of the new valve will go to wherever the PB line is now terminated.
WOODS TS1680 - 14' ROTARY MOWER, 3PT (A64278)
WOODS TS1680 - 14'...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64194)
2021 Mercedes-Benz...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
Year: 2013 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 201,750 (A64557)
Year: 2013 Make...
