Ballast Ballast Box pics (and others)
   / Ballast Box pics (and others) #1
rjkobbeman
USA
Kubota M8540HD-12 2010
Hey everybody:
Some of you have inquired about my ballast box and wanted to see some pictures. It took me a while to get all of the parts to it (one of the lift pins was missing), but today I finally got it together. I have not filled it with concrete yet, however I hooked it up and snapped a few pictures. I also took a few of the tractor itself... but you can ignore those.:D
If you have any questions, fire away...
   / Ballast Box pics (and others) #2
Very nice,! you might want to put in some PVC pipes for handle tools vertically before you pour the concrete. I put in 3, I wish I had put in 4:laughing: they sure are handy:thumbsup:
James K0UA
James K0UA
I have read a lot about that on this site. Sounds like a great idea!
   / Ballast Box pics (and others) #4
I just picked my ballast box up yesterday afternoon. RJ, I think we have the same box. My part number is for cat1, your part number is for cat2? I put tie down anchors on this morning, will silicon internal seams tomorrow, then off to the concrete company. Philip.
   / Ballast Box pics (and others) #5
If you don't mind me asking, how much does Kubota get for those boxes?
Al
I see some subtle differences that indicates they are different boxes. That would make sense since the part numbers are different. The most notable difference I see is the channel iron that runs horizontally across the top that reinforces to top link attachment. On mine, my channel iron is 6 1/2" and goes below the top link attachment bracing.
I'll post another pic later today.
Here are the dimensions of my ballast box, measured at the top ID:
28.75" deep (front-to-rear)
28.25" wide (left-to-right)
32.75" high (top-to-bottom)
I figure it is around 14 cf and should weight around 2,000 lbs when full of concrete.
Kubota listed mine at $575. I got it for 15% off... so around $488. Not cheap for a box, but I don't have the time to make one and I like the looks of factory boxes.
   / Ballast Box pics (and others) #7
Wow, and everyone says that green paint is more expensive!:laughing: The JD box is under $300. But seriously, that's a nice looking box and you will be glad to have it while using your FEL.
   / Ballast Box pics (and others) #8
Thanks for the pictures, nice ballast box and house too:thumbsup:
I need to look into getting something for our M8540. The cab may help some, but we haven't done any serious FEL work yet.
   / Ballast Box pics (and others) #9
I put cement blocks (the solid ones) in mine and then filled in between and over the top with 3/4 inch stones/gravel. Or you could just fill it with 3/4 stone or field rocks. I still have the pvc pipe carriers too. It might not be as heavy as solid concrete but it is pretty darn heavy and it's reversible if something like a pin bends. I think it might drain and dry out better too. Something to think about.
Thanks for the compliments. I still have some minor trim work to do on the house, but for the most part it is finished. I spent all of 2008 and 2009 building it. My wife and I were the general contractors and I did about 75% of the labor. Concrete, exterior framing, roof, plumbing and front stone porch were contracted out. I did everything else.
I have been ripping a bunch of locust trees out of the ground in my pasture. If the cutter is on I don't have much of a problem, but in tight spaces I leave it off. With nothing back there, my &ss end comes off of the ground when I am under the roots and trying to rip the tree out. Getting the bucket wedged under a root then curling the bucket really has a lot of power. I can't wait to get the box filled and start using it.
All in all, I love the M8540... it is very impressive. All of the golfers (we live next to a course) stop and watch when I am taking trees down.
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2008 GMC C5500 Landscape Truck (A56858)
2008 GMC C5500...
Kubota 80 inch Tooth Skid Steer Bucket (A59213)
Kubota 80 inch...
2201 (A58376)
2201 (A58376)
2019 GALYEAN...
