At Home In The Woods
/ At Home In The Woods
Brick work is finished. The mason will have to come back and add flashing over the basement porch and over the main floor back porch ledger board for the deck.
attachment.php
Tonight I started prep-work for putting in the drain tile for the retaining wall. The holes in the drain tile will be pointed downward when I install the pipes. After the drain tile is in, I can finish the grading so the back porch can be built.
The drain pipe that leads from the basement drain tiles had silt that had backwashed into the drain pipe. The fired construction manager we got rid of had backfilled dirt in a way that silt would just wash into the drain pipe. My wife constructed a U-Turn in the end of a water hose. We pushed the water hose into the drain pipe and flushed the silt out of the drain pipe. I used a flashlight and mirror to check the pipe. The water hose cleaned out the drain pipe very well.
/ At Home In The Woods #1,722
Thanks walleyed. You've been kinda quiet.
I'm pretty quiet by nature.. Well maybe not but you are a long way from me and I have no idea about building codes and methods there. I wouldn't want to give you wrong info. Besides the great folks here have looked after you very well.
I bet you are happy to see the end of another big part job (the brick). When were you planning on making the move into the house?
/ At Home In The Woods #1,724
Obed...Nice looking brick job...If you did not have him clean the brick and he wants to charge you extra to clean the brick, if I were you I would pass and save the money since most of the bits of morter will get knocked off and cleaned off by rains and you can also pressure wash it. When we built our house they tried to charge me $1,000 to wash it off...I passed and did it myself with a pressure washer.
Where are you with your interior subs?
This week the insulation work should start. We've picked the drywall sub and the cabinet maker. We haven't picked the rest of the interior subs (hw flooring, tile, painter, trim carpenter). Have I forgotten any?
In addition, vinyl siding and soffits, gutter installation, and back porch framing should start this week. We've lined up the stone mason to lay the stone when the vinyl siding work is finished.
Obed
Bob,
We already have someone lined up to clean the brick. They use some kind of chemical to clean it with.
Obed
This weekend we were able to backfill and grade the area under the back porch so the porch work can start this week. The weather forecast was kind of bleak, 50% chance of showers Sat and Sun. However, it was clear and hot until it rained at about 5 PM Sat. I was able to get most of what I had to get done completed.
I was very thankful for the weather. It was extremely hot and miserable but dry enough for us to get the backfilling completed without having to delay the back porch construction. A lot of the backfilling work had to be done with a hand shovel and mattock. It was so hot that I had to take many breaks; I'm not acclimated to working in such hot conditions. This summer has been hot. August has averaged 5 degrees above normal. Every day except one has been over 90 degrees F, many have been in the upper 90's. I really feel for the brick workers having to work in this weather.
When I got up Sunday I was very happy as I thought I didn't have any work to do that day. However, my wife noticed that I had not backfilled along the backside of the garage wall footer where the deck and porch will meet the house. I had totally forgotten to do that section as I hurried with the retaining wall drain pipe and backfill before the rain started late Sat afternoon. So Sunday morning, we spent 2 hours backfilling the garage footer. Also, my wife wanted the grade next to the retaining wall and below the door to be higher so we added more dirt.
The drain pipes at the bottom end of the retaining wall still need to be connected so I haven't backfilled that section. I put some plastic over the area to help minimize silt from getting washed onto the lower drain pipe.
This weekend, I removed some brick debris from the area where the back porch will go. The brickies were a bit wasteful with the mortar at times. Some days they would mix up a batch of mortar; reach the end of the day, and leave half a wheelbarrow full of fresh mortar to waste. You can see some large chunks of the wasted mortar in the picture. I dumped the brick waste below our culvert where it tends to wash.
The wife picked up with the nail magnet nails for the brick ties that were dropped on the ground during the work. The magnet has been well worth the cost for our construction project.
/ At Home In The Woods #1,730
Obed,
The house is looking great. Soon the outside will be finished and you'll be wrapping up the inside.:thumbsup:
Just remember...
...no more shoveling snow in the living room. :D
...and no snow angles in there either.:laughing:
/ At Home In The Woods #1,731
Putting them to use :thumbsup:
I really like the way the outside of your house is coming together, and I agree those nail magnets are worth it! We got one after our roof was redone and keep finding nails, bolts, screws, and more not just from the roofers!
After a hard rain, and after winter it's great to go use it again and fine pounds of nails :laughing:
Obed,
Just remember...
Cyril,
Yes, I hope those days are behind us.
Vinyl work started today. I don't have any pictures yet. It started raining late this afternoon.
Getting an insulation company we liked was a struggle. We want to insulate the ceiling between the main floor and the attic. We have 18" high trusses between the main floor ceiling and the OSB that covers the attic floors. The trusses are at 19.2" O.C. Insulation companies were actually giving us quotes for laying 16" wide batting between the trusses. They were not going to put any insulation on top of the 2x4 bottom cord of the trusses. So for every 19.2" of ceiling we would only get 16" of insulation. Over 15% of our ceiling would not get insulated if we insulated it that way.
We found a company who was willing to work with us. The ceiling insulation will be blown from the attic. We will have to remove a bunch of the OSB off the floor in the attic so the insulation company can blow the insulation. In the middle/open sections of the attic, we can remove every other row of OSB. It gets trickier behind the knee walls. To remove the OSB flooring behind the knee walls, we will have to cut the OSB because the knee walls and roof braces are sitting on top of the OSB. We have a lot of space behind knee walls.
/ At Home In The Woods #1,734
I'd skip that particular process and instead spray foam the underside of the roof and its joist areas and the same with the inside of the exterior walls from the soffit area up to where the roof rafters meet. Then install fireproof rated sheetrock on the rafters underside, as well as the knee wall areas. Put enough solid (closed cell) spray foam in these areas and you won't need to do anything else to insulate/ keep the attic and rooms below heated or cooled.
Flashing/Siding/Brick/Roofing Question
We are trying to figure out a good way to keep water from running behind the brick at the spot in the picture that is circled in yellow. Does anyone have any good suggestions?
attachment.php
Thanks in advance,
Obed
Siding Pictures So Far ...
The siding guys are Russian; their English is ok but not great. They put aluminum around the bottom of the front porch beam and slid the temporary roof support poles under the aluminum.
Not much work got done today. The siding guys got here mid-day, ate lunch, and left. The framers did not make it. The stone guy worked a half day today.
You can also see the new brick work around the porch. The brick cleaners finished cleaning the brick in one day. They used a muriatic acid solution with brushes and scrapers.
/ At Home In The Woods #1,738
Kickout flashing, both on the wall and the roof at the joint. Given the short distance you are dealing with, taking the brick all the way to the top may have been easier, but obviously that isn't realistic at this stage.
Stone work started today.
Dave,
We did consider bricking the dormer sidewalls but doing so would have required additional framing support to that section of the roof. In fact, the brickies accidentally laid brick on one side of the dormer and we had to make them tear it down.
What is kickout flashing?
Thanks,
Obed
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
John Deere 5090GN (A60462)
John Deere 5090GN...
