Is it possible to add more Rear Remotes and a 3rd SCV???
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #1
deere4320
Northwest CT
2008 Deere 4320 eHydro w/400X FEL and Unloaded R4's
Hi All,
On my 4320 i currently have 1 rear hydraulic remote. Would it be possible to add more to my tractor?? I have seen tractors with up to three on tractors. What is the maximum number of remotes and how much would it cost to add 3 to my tractor. Also I have seen 3rd SCV's installed on tractors by the factory. I like this better because it is easier to operate the FEL mounted plow since the button that controls the 3rd SCV is right on the joystick compared to the add-on kit that i have seen where it is an actual lever which i could not operate the loader at the same time as the hydraulic angle. Thanks for all you help in advance, i am fairly new the hydraulics.
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #2
Anything's possible. How much do you want to spend, who will be doing the work, and how extensive of a mod are they willing and able to do? I think that is the main question.
Joe
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #3
There are a few ways of adding additional hydraulics through your dealer - there are also aftermarket options, but I will let others (with more experience explain those)
The 4x20 series come standard with Mid Mount Valves (1&2) that normally would control lift and curl functions on your loader. The 3rd SCV Kit (Factory or Dealer installed) is a separate valve and is lever controlled. This lever is positioned basically next to the 3 Pt Hitch lever and the outlets are mounted behind the seat, facing to the rear.
There is also a 4th & 5th Electric Diverter kit available as a Dealer installed option. (it can be added at any time) This Diverter kit adds two additional outlets at the rear of the tractor and an electric switch which controls the flow from valves 1&2 between the Mid Mount outlets (1&2) and the rear outlets. (4&5) Because of the way this is set up, you cannot use both the Mid Mount outlets and the Rear outlets at the same time.
What gets confusing is if you add the diverter without adding the 3rd SCV kit - and this is done all the time depending on what the operator wants/needs. In this case the Mid Mount outlets remain 1&2 and the Diverter becomes 3&4 - I hope that made sense.
What some operators dont care for with this system is twofold - that the loader functions and dual rear outlets can not be run at the same time (because they are in fact the same set of valves) and/or that there is no way to have lever controls other than the single lever for the 3rd SCV, which is its own valve.
Last week we received some information on new hydraulic options for 2011 3x20 and 4x20 series tractors and it looks like there will now be a separate, lever controlled, 2 valve kit available (and no, it will not retrofit back to the 2010 and previous models) as well as the original Electric Diverter kit and a new EH (electro-hydraulic) 3rd SCV kit that has a on/off switch on the right fender pod with a 3 function joystick - it should be great for grapple buckets, 4 and 1 buckets, etc. It does not look like the original, lever controlled 3rd SCV kit will be available anymore.
Anyway, I hope this helped!
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #4
I'm glad to learn I'm not the only one to be dissatisfied with the dual rear outlets.
Neither the FEL nor the 3pt hitch can be used at the same time as the 3rd SCV. BleedGreen could you please expand on your explanation of this phenomenon.
The single lever control is only adapted to very basic tasks. You cannot leave the valve open (to use a log splitter for example) unless you tie the lever.
Very sad the new developments will not be compatible with older machines.
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #5
Adding hydraulics is only limited by your imagination. It really helps to get a boost by ordering the stock power beyond option, but even that can be user configured. To get you enthused, here are pics of my year 2009 JD 3720 installation:
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #6
I'll second that. My tractor came with a rear remote and I added a joystick for an additional 2 ports and routed the rear remote through a selector valve to give a second option for the lever. Recently added a backhoe and just put it in the loop.
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #7
He was describing the "electric diverter" that gives you the 4th and 5th SCV. No phenomenon, works as designed.
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #8
Bleedgreen,
Sounds like the new setup will be the same as the 110tlb with the diverter being a three section unit. Never understood why the 4520 was not available with the three section diverter valve.
Bleedgreen and Kenny D,
Is there anything wrong with putting two tee's in the front aux circuit to allow for an additional set of coupers at the rear. I rarely use the front aux couplers and recognize you would need to use only one pair (front or rear) at a time. Right now I have the three section diverter valve with three sets of rear outlets, if I can tee into the front aux circuit I could have four sets of outlets at the rear and have full control of a hydraulic rear blade with the joystick. This would still maintain the boom and curl circuits to work too.
To be more specific are the couplers able to withstand the system pressures while unplugged in this scenario? I would rather not have to add shutoff valves.
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #9
Thanks for the pics, and I'm impressed with the design and the accomplishment.
The pics leave me "somewhat" enthused. But the added clutter leaves me with the desire to find a better design, or do without.
No offense meant, but are the lines extra heavy duty or large and necessary, or could they be smaller such as 1/4" or 3/8" ?
And the control valve assembly? Could it be a bit more petite?
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #10
Is there a specific part number on that new rear hyd? I need to have mine done but want to make sure they dont hose me with the old style...
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #11
Go for it. As long ones set of couplers is empty you will not have any problems.
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #12
Thanks for the response Kenny D.:)
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #13
The suppply and return hoses are 1/2" (that's inner diameter), size determined by JD for the expected flowrate. To use smaller hoses would work, but limit flowrate and cause a continuous heat-generating restriction. Likewise, valves are spec'ed by flowrate (and pressure), and this one is just slightly higher flowrate rated than my 9 gpm tractor. From memory, it is a Prince sectional and is rated 12 gpm. All the front-end lever mounting and remoting is home-brewed to allow mounting the valve back where there is room and to put it where the work is, but bring the controls forward to where they are easy to operate.
340 hours on the tractor with this hydraulic setup and it is working great and I am happy with it. Here is a bit more info on the original thread:
http://www.tractorbynet.com/forums/...2-hydraulic-valve-toolbox-bracket-3720-a.html
Its always possible to make things more compact and tidy, and maybe you will find the way. Just be sure to buy components rated for the flowrate you have (Hydraulics 101), to maintain efficiency and keep from making a lot of hot oil. Also, I recommend keeping in mind serviceability. If you jamb everything under the fender it will be a bear to hook up to, and nightmare when you want to repair or improve. The stock loader valve is a good example. If you need to work on it, plan a half day to get it out of the tractor.
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #14
Jim
Good points, and appreciate the info.
Guess I'm thinking that occasional use (adjusting links, hyd cyl repositioning, and such) could be done with restricted flow, but then if a hyd. motor would need more flow (would include running a splitter too and backhoe too).
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #15
Jim
Um, let me clarify one point. What you say is correct (remotes for top and tilt, spout rotation, etc, could run slow due to small hose diameter, and still be perfectly acceptable). BUT, you still must install a valve rated for the tractor's max flowrate, or higher, and plumb it with appropriate hose size. The valve is plumbed into the flow. Everything on an open center system is in series. Any valve body installed must easily flow the full volume, even when no selector circuit is actuated, or restriction and heat are produced. So installing a slightly small (flowrated) valve with slightly undersized hose will cause the operating temp of your entire system to rise, and all other functions (like loader and 3-point) to run slow. Items that require the highest flow, like backhoes, are typically tapped into the power beyond ports. Power beyond allows being able to cut into the flow loop, open it up, and insert your backhoe valve for full flow.
Hope that helps...
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #16
Jim
Hope that helps...
Jim is 100% correct. Basically what he is saying (just to summarize or say it a different way) is that the "work" ports can be plumbed with small (1/4") hoses, but the IN and OUT ports must be sized to the tractor's system since the flow is constant through them whenever the tractor is running.
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #17
Thanks, the point made is loud and clear, and accepted as good information to have under the belt. I was thinking of the work ports (and not thinking about the flow through the valve set). Appreciate the clarity. :)
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #18
Hello Jim,
I certainly hope that your Dad is still around, to realize just how wrong he was about you as a 12 yr. old kid. I know that I am impressed!!
Regards,
Bob
   / Is it possible to add more Rear Remotes and a 3rd SCV??? #19
Hello Jim,
Regards,
Bob
Well Bob, thanks much for the compliment. You sure have me wondering where you got your information about me and my Dad. Makes me think we maybe know each other, maybe one of my posts I forgot about? Anyway, Dad passed away over four years ago now, but would be thrilled, I am sure, to know I have kept the farm together and am planning on living there soon. He was the smartest man I ever knew, in ways most of the Engineers I work with today couldn't comprehend.
P.S.; WELCOME to TBN !
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2088 Chevrolet C7500 Altec TA40 41ft. Bucket Truck (A59230)
2088 Chevrolet...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
