Buying Advice Kubota B9200
/ Kubota B9200 #1
cordell
kubota b9200
I'm new to the tractor world and have a chance to buy a1990 B9200 with a Bradco backhoe for $10,800. It has 4 wheel drive power steering and a BF300 front loader 947 hours. Looks brand new. 23hp 4cyl Kubota v1200 diesel. PTO rear and mid mount, hydrostatic transmission
is this a good deal?
Cordell
/ Kubota B9200 #2
Welcome to TBN.
Have you visit your local Kubota dealer check out same hp w/fel & bh pricing,maybe be tad cheaper in the long run purchasing new.
Will the owner let you take for spin..try out fel & bh,check for leaks etc.
/ Kubota B9200 #4
Cordell
Are you sure it is a BF300 loader, I'm pretty sure that should have a BF350 loader on it. One of my favorite B-series tractors. The 4-cyl engine is so smooth. It sounds like a good deal to me.
Brian
/ Kubota B9200 #5
/ Kubota B9200 #6
There is no timing chain on that engine, but yes they did have a problem with the timing gears. I only ever saw one engine that had to be repaired myself.
Brian
Morning again Brian,I knew someone would remember those from back then.I just wanted to show Cordell what Tractor Data. had written in there.
Boone
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 John Deere 1795 Planter (A63109)
2016 John Deere...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2022 Ditch Witch C16X 36" Dig Depth Trencher (A64047)
2022 Ditch Witch...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
