Sickle Bar Is there a 3 pt. sicklebar mower on the market?
   / Is there a 3 pt. sicklebar mower on the market? #1
Old Corps
I've got a farm where the trails and roads all have cutbanks and steep offsides, and there's enough brush to require something I can run off the back end of my Kubota 4330. I'm thinking a modern version of the sickle bar mower, perhaps a hydraulic unit. I've got the rear mount aux. hydraulics, so that parts covered.
I looked into a rotary cutter for my old Bobcat X231 excavator, but they want 8 grand for it-that's nuts !!:(
I recollect seeing and even operating something like this years ago on an old Ford 8N. It was about 8 or 10 feet long, ran off rear pto and had a series of belts and pulleys always needing adjusting. Noisy old thing we used to cut hay with. Would rather find a commercial unit than try to adapt or fabricate one.
Any suggestions or ideas are welcomed. Thanks.
   / Is there a 3 pt. sicklebar mower on the market? #2
Several brands to choose from. New Holland, Kuhn, Sitrex (probably). Google is your friend.
   / Is there a 3 pt. sicklebar mower on the market? #3
One of the TBN advertisers, Ken Sweet, sells them. You might want to check with him for a quote.
Sweet Farm Equipment Co.,Disc Mowers, Compact Tractors,Implements, Ship Nationwide Daily
Steve
   / Is there a 3 pt. sicklebar mower on the market? #4
   / Is there a 3 pt. sicklebar mower on the market? #5
Check out the Frontier brand sickle mowers avaliable through John Deere
www.buyfrontier.com
I have a 7 footer with hyd lift and love it!! I have owned 3 different sickle bar mowers in my life and this one rocks!!:thumbsup:
   / Is there a 3 pt. sicklebar mower on the market? #6
Here is a new 7 ft Superior sickle mower with hydraulic cylinder that we sell for $3695 + shipping and with your zip code we can figure that for you. Ken Sweet
   / Is there a 3 pt. sicklebar mower on the market? #7
If you need a longer cutter bar, we have 2 used International Harvester #1300 sickle mowers that are 9 ft cut. One is $1495 and the other is $1750 + shipping. They never had hydraulic cylinders and never needed them. They will mow 90 degrees vertical or 70 degrees below horizontal. Ken Sweet
   / Is there a 3 pt. sicklebar mower on the market? #8
You might check out CCM Equipment and their drum mower.
It looks pretty impressive.
I have looked at them and thinking of trading in my JD 9W for one.
Dave
Wow! Great information. Thanks to all. Ken, I'll check with you by phone after I do a little homework on these options.
Tim
   / Is there a 3 pt. sicklebar mower on the market? #10
If it wasn't for TBN, you sure wouldn't know they were still made. I checked into buying one several yrs ago, couldn't find a local dealer very interested in selling one. One dealer said he had to order them 2 at a time, and he didn't want another one sitting around. ended up getting a used one.
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
9ft 4in Flat Bed (A57453)
9ft 4in Flat Bed...
2008 Genie GTH-844 Telehandler (A57453)
2008 Genie GTH-844...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
SUV (A59231)
SUV (A59231)
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
