LA105 Rub
/ LA105 Rub #1
stihlman32
LA 105 42" deck. Right hand spindle & belt rubbed through the plastic cap. Replaced cap, same result. Anyone else run into this issue? What may be the cause?
/ LA105 Rub #2
Is you belt oscillating side-to-side a lot or does it rub all the time because the shield is too close to the spindle? If it is rubbing through the top, you can put some washers under the shield on top of the deck where the bolts go through to raise the shield up some. If the belt is flopping around, make sure the tension pulley is not binding. The tension arm with the spring needs to be lubed well and free to swing to keep the belt tight. If the belt doesn't have the proper tension, it will flop around.
...just some random thoughts.
/ LA105 Rub
The belt and pulley rubs on both sides of the cover. I replaced the belt earlier this spring and it is tensioned properly. Originally I thought I had torqued the cover down crooked causing the rub, but when the new one went on, I made sure it was square and plumb to the deck. Fired it up, and the pulley is rubbing the cover again! Arghhhh.
/ LA105 Rub #4
My LA135 (42" deck) does the same thing on both sides. This is my first year with it and I noticed it when I did the initial service. Belt tension was set properly according to the manual. I haven't talked to the dealer about it yet.
It appeared to be related to the belt being loose due to the way the mechanical PTO works.
/ LA105 Rub #5
This seems to be an engineer's better idea of belt retainers. They even went the extra step and molded a steel pin in the plastic in one location of one guard. Maybe more but one is all I've seen. You won't see the steel pin until the belt wears through the plastic.
/ LA105 Rub
I didn't have the pin in mine, and it rubbed all the way through the housing on the front side. Might as well not even have the guard on it!
/ LA105 Rub #7
I did take mine off for awhile but the belt would come off occasionally so I cut a couple of large arcs out of them with a coping saw to make cleaning easier and re-installed. They'll just have to rub cause I got better things to worry about.:laughing:
/ LA105 Rub #8
mine does the same thing the right side came with guide holes in the plastic housing and the left side has steel rods in the plastic. i took mine off due to them being worn had no idea they were needed to hold the belt on
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2022 TAKEUCHI TB216H EXCAVATOR (A64279)
2022 TAKEUCHI...
2022 John Deere 616R Sprayer (A63111)
2022 John Deere...
2015 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2015 JAYCO...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
