Cheap chop saw motor brushes source
/ Cheap chop saw motor brushes source #1
lhfarm
Central Indiana
NH TC40DA
Have a cheap Chinese chop saw (from a box store) and have been using it to cut bricks. Burned the brushes on one side. Can't find the paper work or a model number on the saw. Was wondering if I could find replacement if I took a brush in to a motor report shop - or if I'll get tossed for buying junk. Suggestions for a source?
Thanks,
/ Cheap chop saw motor brushes source #2
Our local Ace Hardware has an assortment in there mis. screw section,, I would think most of the smaller non big box stores have them,,
Exactly the info I was seeking. Unfortunately, all the local hardware stores are gone around here. Still, it might be worth a trip to the nearest (20 minutes each way).
/ Cheap chop saw motor brushes source #4
if you can find one slightly larger than you need it can be ground to fit the holder.
/ Cheap chop saw motor brushes source #5
The brushes on my 'junk' Chinese grinder finally packed up after 10 years of pounding and abuse. (I think I put in the supplied spare set of brushes about 5 years ago.). Anyway, look in the yellow pages for 'Power tool repairs.' I discovered one existed about 5 miles away and they had brushes to fit for about $6.
/ Cheap chop saw motor brushes source #6
I want to say that you can find replacement brushes for name brands at big box stores. as noted just grind them to fit the holders if not an exact fit.
/ Cheap chop saw motor brushes source #7
grind is a confusing use a file or piece of emery paper to size them
McMaster-Carr
page 397
tom
Success! After a stop at two box stores and a Rural King, I finally found a commercial motor repair shop. A very nice service person spent 10 minutes trying to find a pair that would work. I did have to sand them down to size, but they worked great.
One of the box stores was were I purchased the saw. They didn't have a clue where I might find brushes. In any case, thanks for all the suggests.
Back to cutting bricks.
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2017 TOYOTA CAMRY SEDAN (A59912)
2017 TOYOTA CAMRY...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
