Honda Fg110?
/ Honda Fg110? #1
powerstroke444e
Central IL
more orange than anything
I am looking for a new mini tiller and did not know what everyone thought about the honda's?? I liked the mantis but really like the honda 4cylce & the honda is $349 @ local dealer which is a little cheaper than mantis.
/ Honda Fg110? #2
not sure about the mini but we got a honda f501 and its been bulletproof for over 10 years.
if the mini is as good as the 501(and it likely is) then your not making a mistake
/ Honda Fg110? #3
I've got the honda. It has been trouble free for three years -- just got it out of storage and it started on 3rd pull. Barely uses any gas. The oil changes are a bit of a pain though -- no drain.
/ Honda Fg110? #4
/ Honda Fg110? #5
i dug one out of the neighbor's junk pile....took it down to the house, put some gas in it, checked the oil and it fired right up....one of the smoothest, quietest running engines i've ever heard....
this one had the gear box stripped out like a lot of them do...honda uses someone else's gear box.......
anyway, after i heard it run so nicely, i spent $53 on new gears and seals.....buttoned it all back up....ran it for a while..........found two thrust washers laying on the work bench that i had forgot to install!!!:(
that was at the end of last years gardening season....i'll tear it back apart soon...
seemed like a very refined little machine......
/ Honda Fg110?
Thats what I wanted to know. Looks like I will go pick one up after work today.
/ Honda Fg110? #7
Were you able to go get one? I'm hoping you'll give us a report on one. I'm interested in one to help with the amount of weeding I have to do.
/ Honda Fg110? #8
i prefer the honda to the mantis . i bought the 2 cycle mantis a couple of years ago and it has worked well for me , but my dad has the smaller honda with the 4 cycle motor . much quieter , easier to start , and i think a better value for the money .
that 2 cycle whine gets old after awhile .
/ Honda Fg110? #9
I have the 100 not the 110. Be forewarned if the lower unit is made by Hoffco like on the 100 keep it greased. I have been through 2 lower units gear sets so far. First one because I didnt know about the grease in unit. Second time because the POS brass worm gear drive.
The Honda GX motors are great and quite though.
/ Honda Fg110? #10
I just bought a Honda mini, used it just once so far but I love it. Started right up, first pull. I removed the wheel assembly to cultivate my veggie garden. The gas tank is tiny, and it ran about an hour. When I refilled it I poured gas all over the place. I knew the tank was small, it's opaque and right there in front of your face, but it took less than a drinking glass full. :thumbsup: If you want to till in between things like potatoe plants, you can remove the 2 outer tines simply, and get it down to 5" width. I used mine sideways to till up the soil and hill the potatoes.
/ Honda Fg110?
Finally the follow up
I have put 6+ hrs on the honda 110 and would say that i like it better than the mantis my dad has. I have used the cheapy from TSC and cheap sears before and this is much better. 1st thing I did was take the wheels off as I see no reason to use them. I would reccomend this model to other TBN members looking for small tiller.
/ Honda Fg110? #12
.... 1st thing I did was take the wheels off as I see no reason to use them. I would reccomend this model to other TBN members looking for small tiller.
Same result here after maybe 3 hours' use. I take the wheels off for tilling and put them back on for storage. I used it to till weeds from an untended former flower bed and it did a great job, dug deep and didn't wear me out. And it starts so easy! :D
/ Honda Fg110?
Used the little guy quit a bit probbley ran about 5gal of gas through it. Most of the time is put finishing touches on trenching projects.
My 2cents on anyone lookin for a small reliable tiller that starts easy and runs good this would be a good add to the shed. I have used other small tiller and this is much better on the back than most.
And as fyi this has not been in shed since purchase it rides in back of the service truck to every job with no issues.
/ Honda Fg110? #14
Necrothread.
I've had my Honda FG110 for about 4 years. Yes, it starts and runs easily. However this spring when I started it up, I got a puff of blue from the exhaust. It ran for a bit more and now engine oil is coming out of the carb (and fuel is in the oil). I'm assuming headgasket, but I guess it could be horribly bad rings too.
It has probably 60 hours of use on it, but I have to say I'm a little disappointed in the unit.
/ Honda Fg110? #15
If it was tilted or leaning too far over, the oil could have slowly seeped past the rings since the last time you used it. Change the oil, clean the carb jets and floats and then see if its still acting up.
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
UNUSED LANDHONOR SPEAR (A64280)
UNUSED LANDHONOR...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
40' CONTAINER (A64281)
John Deere Front & Rear Rims (A64119)
John Deere Front &...
