over heating 755
/ over heating 755 #1
deere755
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
Does anyone else have problems with the radiator getting plugged up on their 55 series. I washed out my radiator real good, front grill, oil cooler and cleaned the screen out. In 3 hours time of mowing tall fescue I was over heating. Radiator looked like it had not been cleaned in days. Today was a very hot day heat index was around 105. I came back home got the 4700 out and mowed all day. The heat gage never moved over about of the 1/4 of the way off the cold mark. The grill was covered when I got in with it. My 755 has a new radiator, fan and belt. Any ideas on how to keep the radiator clean. If I can keep the radiator clean it will run cool.
/ over heating 755 #2
Maybe add a pre-screen to hold back some of the chaff from getting into the radiator.
Did it over heat befor the new radiator?
/ over heating 755 #3
The parts illustrations shows a pre-screen and a bunch of seals and pads. Are all of yours in place?
/ over heating 755 #4
Agree to check all the seals and pads to insure correct airflow. Most debris is caught in the external grill screen on mine. As an aside, I had previously mentioned a Fuller Brush dryer vent cleaning tool available at Lowes that makes cleaning what does get to the radiator a bit easier.
/ over heating 755 #5
In almost 20 years, mine overheated only once. I had neglected to clean the screen in quite some time, and it was badly fouled with chaff. Once I cleaned it, no more more problems. Of course, being a New Englander, when the temperature or heat index is in the 90-100 range, you won't find me on my tractor, unless I'm in the woods where it's shady.
/ over heating 755
Did it over heat befor the new radiator?[/QU
I never really had a problem with it getting so dirty with the old radiator like I do now. I wiil check all the seals but those were supposed to be replaced with the new radiator.As much as I hate to get rid of my 755, It may be time to replace the old girl. I just have to convince the old girl I sleep with that it is time.
