How to cut a concrete basement floor?
   / How to cut a concrete basement floor? #31
That's what I thought - just got a little confused with what you said about the builder and pool. Glad to see everything went well. You've finished the toughest part of the job. The rest is downhill from here.
Joe
   / How to cut a concrete basement floor? #32
For the shower valve - look at moen. Two advantages:
1. If you screw up and plumb the hot and cold to the wrong sides - it is easily fixed by removing and turning around the cartridge.
2. The valve can be easily repaired/replaced in the future without having to tear into the wall. All you need to do is take the handle and trim off and replace the cartridge.
Also - ball valves to isolate the bathroom plumbing for repairs are a good thing to have (having to turn off the house water suppy to do a simple repair is a real pain).
Good Luck.
Joe
That's good to know about Moen. I was going with them anyways as that's what's in the rest of my house and I have this thing about uniformity. It had not occured to me to put in shut off's to this bath. I will definitely do that! Not looking forward to cutting into the water lines in the ceiling of the bathroom. Being so low I'm guessing every bit of water in the house is going to drain out on me.
Jeff
   / How to cut a concrete basement floor? #34
The other advantage of the shut-offs is that you won't be time pressured by the spouse and kids to turn the water back on while working on the bathroom.
   / How to cut a concrete basement floor? #35
Moen is definitely the best even today.
   / How to cut a concrete basement floor? #37
Hi all,
I'm in the process of finishing my basement. I need to cut a trench in the concrete to plumb in a sewage pump and to put in the actual basin. I had though I would rent a concrete saw but all I can find are gas units which would put out too much exhaust. Any other suggestions on how to cut through the floor fairly neatly? I had also thought about a jack hammer but I sure would think scoring the outline first would make a nicer job of it.
Jeff
First you find out the depth of the concrete. Find a saw that will cut to that depth. If possible use electric, otherwise if your using a gas saw you should have a intake fan and a exhaust fan. A oxygen monitor is always a good idea, and do not work alone. Your concrete saw should have a water attachment to keep the dust down, if not then you can just spray the blade during cutting. Earplugs are also recommended.
If you have any other questions,
click below and go to my website :
Vancouver Competitive Concrete Cutting & Coring - Low in Price, High in Quality!
once at the page push the "Contact us" button and send me a message.
   / How to cut a concrete basement floor? #38
Add that. Check for smoke alarms befoe starting any gas equipment. Ask what happens when you fire up a chainsaw under one.
Harry K
   / How to cut a concrete basement floor? #39
FYI: As per his posts in this thread, the OP cut his floor, and finished this job nearly 6 years ago.
   / How to cut a concrete basement floor? #40
hahahahaha lol I have learned to check the dates too.
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
DEUTZ MARATHON...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56435)
2002 Chevrolet...
