Xtra Armor for 4120,4320,4520
   / Xtra Armor for 4120,4320,4520 #1
mscheer772
Hayward Wisconsin
4310 JD 2003
Does anyone know if JD makes the steel plate for the undercarriage for these tractors
Thanks, Mike
   / Xtra Armor for 4120,4320,4520 #2
I have the factory steel plate on my 110tlb so I will take a look and see if this will work for you.
   / Xtra Armor for 4120,4320,4520 #4
I can still get the armor for my 4200, so I suspect it's still available for your series of tractors. Check www.jdparts.com and search by tractor model number.
   / Xtra Armor for 4120,4320,4520 #5
I'd be very surprised if that were the case. It would be a great feature for the 4000 series of tractors but the frame structure of the two tractors is quite differnet.
The belly-pan on my 110TLB uses the structural support of the rectangular frame that ties both the loader and the backhoe mounting structure together.
Since the 4000 series of loaders are removable there is no structural member that is present to become part of the support framework with the backhoe and the tractor housing that would fit the type of belly pan that is available for the 110.
AKfish
2001 TOYOTA TACOMA SRS TRUCK (A54756)
2001 TOYOTA TACOMA...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2018 JLG 3246ES 32ft Electric Scissor Lift (A53421)
2018 JLG 3246ES...
STEEL SLINGS (A54757)
