BCS Model 715 tiller?
/ BCS Model 715 tiller? #1
Ezzrider
Kubota B7510
I am in the market to purchase a used rear tine tiller. I have seen a BCS Model 715 with a 8 hp engine advertised for sale at $600 locally. Anyone know about the BCS tillers and does this sound like a reasonable price? Supposedly it works fine.
/ BCS Model 715 tiller? #2
If it is in good shape and runs well, I'd think it's worth it. Make very good tillers. Had a 715 with a 20" tiller myself.
Thanks. I have not actually looked at the tiller yet. It is supposed to be in good shape but who knows. I like what I read about the BCS tillers. I had not heard of them until I saw this ad.
/ BCS Model 715 tiller? #4
Make sure you check the oil in the tiller gearbox, stuff wrapping around the shafts can ruin the seals. The gearbox seems to be almost indestructible, but must have oil in it. Seals are not expensive, but a little difficult to replace. There is a good how to here on doing it.
Make sure the transmission has oil in it too.
Check the tines, if they are wore down to a point they need replaced.
If it is good shape it is probably sold. I spend 6 months tracking one down.
/ BCS Model 715 tiller? #5
$600 sounds like a great deal. I paid that for my 730 w/Tiller about 8 years ago.
If it is in good shape you won't be disappointed with a BCS..Also there are a bunch of attachments out there for them.
Thanks for the input.
I bought it today. The owner told me he was the second owner with the original being a farmer down the road. Everything looked ok except the tires had pretty good dry rot but are still servicable. I/we could not find how to check the transmission oil. The owner told me he had not been able to find where to check it and I could not find a place either and he had no book on the tiller. There is a cap on top of the transmission area that looks like a vent cap. Nothing was leaking and I saw no signs of previous leaks. The tiller cranked right up and the transmission engaged in all gears forward and reverse. He tilled up a small area and the tines worked fine. The tines looked ok with no broken or worn down tines. When the tiller first starts up it runs on a high rev for a bit and then slows down. He said that it had always done that. Is that normal. I am hoping I did not get screwed on this but everything seems to work. It has some minor rust but overall looks good.
/ BCS Model 715 tiller? #8
In addition to the tractors transmission oil, you need to check the oil in the tiller. You have to remove the tiller hood and there is a plug on top of the gear box.
Not sure about the high rpm at first, other here are familiar with that engine. Many speak highly of it.
Don't forget you can get other implements for this tractor. It is more than just a great tiller.
Thanks. I will look for the tiller oil plug. I still cannot find the transmission plug to check that.
/ BCS Model 715 tiller? #10
Here is a pic(with circles and arrows) of the dipstick. As per my other post, put it back in with the flat side towards the center of the transmission.
I really appreciate this. I took off the cap and someone has removed the dipstick or it was lost and the hole seems to be filled with some sort of springs? Possibly the original owner lost the dipstick and simply filled the hole? Don't sound right but who knows. You never know with used items. The owner I purchased this from told me he tried to remove that cap but it was hard to remove so he left it in place. I removed it with a set of plyers. I will remove the springs and whatever else is in the hole and try to determine if there is any oil in the transmission. It runs fine so I would think there is oil? Possibly I can order a replacement dip stick? I am VERY hopefull it is ok.
/ BCS Model 715 tiller? #12
I'm lost on the thought of springs being in there, got a pic? Call earthtoolsbcs and they should be able to get you a dipstick. Far as I know all the parts are still available.
We no longer have the 715 pictured so I can't measure the dipstick length either.
I can take a digital picture but I am uncertain of the file size I can download on this site? I will also call earthtoolbcs tomorrow. I just took a closer look. I took out what was in the hole. It is actually some sort of nylon mesh looking plug and not springs. There does appear to be some oil in the transmission but it was hard to see. I shook it and saw some but I do not know what is the proper amount without a dipstick. I does not appear to be dry. I want to drain and replace the oil but I will either need the dipstick or know how close to the top the oil goes.
/ BCS Model 715 tiller? #14
I don't think this site hosts pics, I use photobucket.
Transmission oil filler area that was plugged with a nylon mesh plug and no dipstick.
I took a long plastic wire tie and put down the hole. There was oil on it put to about 6 to 8 inches. The oil was clear and did not smell burnt so I guess I just do not have the correct filler cap. I will check the tine area for the oil tomorrow. Thanks again.
/ BCS Model 715 tiller? #17
I think you just got the top off the dipstick, all the black plastic comes out of the hole and the mesh you see is just part of the vent that is built into the dipstick. Take the rest of that black part out, usually they stick pretty tight, and you will see the rest of the dipstick.
There is nothing else down the hole except for a piece that runs through the middle of the hole a little way down. Are you suggesting I try to pull up the entire piece of black plastic that the cap sat on? That seems to be mounted pretty secure to the transmission. I went out and removed the plastic piece attached to the transmission that the cap was attached to and that did include the dipstick. I REALLY appreciate your help and I need to get a manual for this tiller as I had no clue nor did the previous owner. There seems to be plenty of transmission oil and it is clear with no apparent issues. I will still replace. Do you now what is the recommended transmission oil.
/ BCS Model 715 tiller? #19
You pulled the top off the dipstick, all the plastic needs to come out.
Pictures make things so much easier
Thanks again for your help. Again I do not have a manual for this unit. Do you know how I can check the oil back where the tines are?
2024 CASE TV450B SKID STEER (A64279)
2024 CASE TV450B...
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
2002 Pace American of Texas T/A 26FT Enclosed Trailer (A61573)
2002 Pace American...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
PALLET OF PARTICLE WOOR AND 4 X 4 POST (A63291)
PALLET OF PARTICLE...
