Mowing Kubota ZD21 won't start
   / Kubota ZD21 won't start #1
stsimon
It has 1000 hours and a fairly new battery. It doesn't crank at all, just a click when I turn the key to start. Prior to replacing the battery recently it wouldn't always start when hot. Now it won't start when cold. Cold is relative, since the temp is in the 90's. Ideas?
   / Kubota ZD21 won't start #2
If this machine uses a Denso style starter like many Aisian motors, it may have worn starter solenoid contacts. There are two copper contacts under a triangular cover on the starter held on with three screws. If your starter looks like this, you are in luck, starter contacts are really cheap and easy to intall. To diagnose worn contacts, keep trying to get it to crank. When you keep trying it over and over again rapidly, the contact will probably hit just right and the starter will work. If this is the case, pull the starter and get some contacts.
   / Kubota ZD21 won't start #3
Mine is doing the same thing. Where can contacts be found?
   / Kubota ZD21 won't start #5
If the starter solenoid is'nt the problem, I'd move on to checking the safety switches.
40' CONTAINER (A52706)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 RTVXG-850 SideKick (A56435)
2023 RTVXG-850...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
1667 (A57192)
1667 (A57192)
2020 DRAGON ESP...
