Buying Advice Can't find a Ford 770 loader
   / Can't find a Ford 770 loader #1
greenispeace
Ford 1700
Anyone with any leads or tips on a Ford 770 FEL, your help very much appreciated. I'm located in WV and own a '82 Ford 1700 4wd. I have a Ford 201 snow plow on the front now I'd like to sell once I find a 770. Thanks.
   / Can't find a Ford 770 loader #2
I'm in a same pickle as you're in. I looked high and low to no avail. There are many options on new loader with much better joy-stick option and adaptor kit for 1700. Koyker is good one to be had but between $3500 to $4000 is somewhat prohibitive with that vintage tractor. Best deal I have seen is 1700 with a loader @ about $6000. If your loader work is simple and limited just like picking and dropping a load of manure then dirt scoop might not be a bad choice.
JC,
   / Can't find a Ford 770 loader #3
Also worth checking out would be a good used DuAl 105. It's about the same physical size as the Ford 770, as far as I can tell, but I believe it's built a little heavier and the lifting capacity may also be a bit more. I have a 105 on my 1510, and it's a good fit.
Of course, some of the veteran members here may be able to straighten me out if my comparisons are wrong. ;)
Thanks for the advice, I'll keep an eye out for the DuAl 105. I've been keeping on eye on the web but in June for some reason I didn't and too late discovered a 770 in Tenn. that went for $300 at auction. Looked in good shape in photo. Snooze you loose.
   / Can't find a Ford 770 loader #5
I also need a FEL for my Ford 1700. I have a "NEW" Bush Hog FEL M146 without mounts, bucket, or hydraulics to sell or trade....I can not find the mounts for this model to fit my tractor. I suppose one could build them...
   / Can't find a Ford 770 loader #6
Have you tried World Wide Tractor Parts in Bellfontaine Ohio ? Long Lane Tractor in PA ?
   / Can't find a Ford 770 loader #7
I have a Ford 770 Loader still mounted to a Ford 1300 2wd. Tractor has a bad clutch, loader works fine but has a few leaks. $3000 for all or $2500 for the loader. Bryan 920-779-4468 text OK
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
1644 (A57192)
1644 (A57192)
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2017 Ford Fusion S Sedan (A55853)
2017 Ford Fusion S...
