JD2305 wheel weights for a Kubota BX2360
   / JD2305 wheel weights for a Kubota BX2360 #1
OrangeRidge
Gold Member
Mapleton , Queensland , Australia
F3690AU 72"
Kubota Australia don't import the iron wheel weights for the rear 26 12 12.
John Deere do have weights for the JD2305 26 12 12.
Does anyone know if the JD weights can be attached to the Kubota
metal rims , or are the hole alignments/bolts different ?
JD service didn't know what the Kubota wheels looked like.
(May have to take a rear wheel off when the BX2360 arrives , and visit JD)
Thanks,
Neil
   / JD2305 wheel weights for a Kubota BX2360 #2
I would expect that all the SCUT wheels arre the same, but it wouldn't hurt to double check unless someone here actually has both like TripleR.
I think you're right :thumbsup:
Found this excellent photo posted by JohnThomas.
The BX2660 26 12 12 has 4 square holes in the
inner rim , as I believe the JD weights system requires.
This would be good because I don't really want to liquid fill
the tyres TBH . The JD weights (BM17972) are 55 lb each
which is enough at the low CG to help with stability.
   / JD2305 wheel weights for a Kubota BX2360 #4
Neil, I didn't check my weight interchange book but I'd lay odds on it they would fit!
   / JD2305 wheel weights for a Kubota BX2360 #5
Thanks for the photo Larry. I reckon these things are a
standard fit for a generic spec rim . I'll have to paint-out
the JD yellow cast iron to grey ;) :laughing:
   / JD2305 wheel weights for a Kubota BX2360 #7
Yeah, yellow and orange just ain't gonna get it I don't think:laughing:
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2015 CATERPILLAR D9T CRAWELR DOZER (A51242)
2015 CATERPILLAR...
2016 BMW X5 SUV (A50324)
2016 BMW X5 SUV...
