Stihl - 260, 270, or 280
   / Stihl - 260, 270, or 280 #11
gentleman, I offer this advice. I recently started cutting and burning wood for heat in N NY. I bought a cheap husky 350( told it was a good homeowner saw, just what I needed at the dealer) It was a pos. got rid of it after a month. I went to stihls and currently have an addiction to them. I have a couple ms 361's(one is brand new just in case as I really like this model) and a ms460 rescue( mainly because I got a great deal on it and it looked cool)
If I were to get another saw it would be a ms260 PRO not just the ms260, as stihl makes both. The Pro has a few differences .
The main differences between the 2 ms260's are
MS260 PRO, has decomp and an adj oiler.
Ms260 has fixed oiler and no decomp.
The 270,280,290,310,391 etc are in a different spectrum and are not lifetime saws. They are better than some but if you can swing it get a pro series as the whole saw is better constructed, and they are alot easier/cheaper to work on if needed.
The ms260 is to be replaced with a ms261 sometime soon.
Only the 260 pro is shown on the website and the local dealer only has the 260 pro model which makes me think 260 has been discontiuned.
   / Stihl - 260, 270, or 280 #13
I have been buying Stihl chainsaws and weed eaters for decades. The Pro series is the level of performance Stihl started out with. It's not really an upgrade. It's when they introduced the "Homeowner" series that the Pro series became a choice. The "Homeowner" series is cheaper and lighter duty saws and weed eaters. "Occasional Use" as they say. There is a need for this lighter duty stuff but not for me.
What would equate to the 039 Farm Boss? I've literally run hundreds of tanks of fuel through it without any issue (after I lost that dang spark arrestor). It will pull a 20" bar no problem but does get heavy when trimming some low limbs of a few hundred oak trees I have around my property. I consider it a great saw.
I recently purchased a Stihl FS 250 string trimmer, and it's a beast and easier on the fuel than my old FS 106. I also bought Stihl's new 2010 model BR600 blower (man, it's nice!) and the FC 110 edger. I wish the edger would spin in the opposite direction. My old Troy Built edger turned away from you and threw the trimmings out in front of you. That's not as important as the Stihl trying to run away from you if you hit a heavy dirt packed area.
   / Stihl - 260, 270, or 280 #14
Believe the MS390 replaced 039.
   / Stihl - 260, 270, or 280 #15
In the last year I bought a Stihl 260 Pro and an Echo CS-341 arbor saw. I use the Stihl to get the trees on the ground and the echo to limb and cut up.
The Decomp on the stihl is a god send. I bought these saws for two reasons, one was the brand and the other was the weight.
Wedge
   / Stihl - 260, 270, or 280 #16
Correct! The MS390 is considered one of Stihl's Landowner saws; it falls in the line-up between the Pro Series and the Homeowner line. The 390 (and the 039) are great saws for the money, they are a little on the heavy side when you look at power to weight ratio within the Stihl line as well as the other top brands, but all-in-all, a pretty decent saw.
   / Stihl - 260, 270, or 280 #17
I,v got the 260 pro and love it.The decompress button is a must have for me.:thumbsup:Dave
   / Stihl - 260, 270, or 280 #18
Wedge
I have the same combo and it works well for me... I keep the Echo CS-341 in the truck and it is always ready to go...
Digressing a little, I received a new Craftsman Saw as a gift from a neighbor a few years ago... it leaked oil just sitting and the fumes from the fuel on a hot day were very noticeable... there was no way I could lock it up inside my vehicle...
Don't have that problem with the Echo... even cut up a 32" dia tree enough to clear the road during a storm... the little saw just kept going... glad I had just sharpened the chain.
   / Stihl - 260, 270, or 280 #19
I have a 280 and it is a great saw. I use it 5 or 6 times a year and have never had a problem. I also have a smaller echo for trimming and I like it as well. It is light duty but also light.
You could also go to arborsite and kill a bunch of days researching
   / Stihl - 260, 270, or 280 #20
I have a MS280 and I really like!!!!!:thumbsup:
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2008 Ford F-450 Service Truck (A53422)
2008 Ford F-450...
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
CATERPILLAR CS563 ROLLER (A52707)
CATERPILLAR CS563...
2016 Ford F-550 Altec Bucket Truck (A55852)
2016 Ford F-550...
