Mowing Violent start of rotary cutter
/ Violent start of rotary cutter #21
I have a DK55c with a Rhino rotary cutter/mower and it shakes violently at start-up, someone told me that is normal
/ Violent start of rotary cutter #22
If you were close enough to the shop, we'de let you borrow a slip clutch to try it out. We ain't guessing about this, we did it , tested it, and have used it on several DK tractors for our customers with rough cutters and finish mowers. The little slip at start up is just enough to soften some of the kick-in. With a 72" rough cutter, some customers were shearing pins just on start up. Rough cutter blades tend to congregate to the same side of the deck when you shut them down. At start up, you have to get the blades moving so the angular momentum throws the blades back out in balance. With the e-hydro engagement, it causes a pretty violent start since you can't feather the pto. The slip clutch just takes a little of the "shock" out of the inertia needed to get the blades moving. Gives it a small amount of feather. They dont' offer the same feathering as a clutch but they also don't slip enough to cause a performace problem with the implement. Quite the contrary, they tend to cause th rotory implement to run smoother and protect the tractor pto clutch from impact loads.....
.....BUT............
/ Violent start of rotary cutter #23
Although what you say may work, it is not how a slip clutch is designed to work. If I start the mower at 1/2-2/3 throttle and allow the slip clutch to slip, to get the mower going, how is the slip clutch going to perform at full throttle under a heavy load? It will slip excessively and burn out the clutch. I think the reason it works for your customers, is because they mow relatively light duty grass/weeds and don't make the clutch slip at full pto speed. I would guess, the hardest the mower ever works is on start up for your clients. I have several attachments with slip clutches for CUTs and Ag tractors and would never allow a slip clutch to be so loose to slip on start up.
/ Violent start of rotary cutter #24
radman,I never start my pto at 1/2 or 2/3rds throttle,start at idle.[Maybe thats not what your doing either,but from last statement,not sure]
/ Violent start of rotary cutter #25
Hi! On Massey Ferguson 1600 serie( mine is a 1643) there is a special button that we can depress if we want a **gentle ** start of the pto. We depress it and then put the electro magnetic pto start ( and cancel it after it is running for a few seconds). It gives a softer ( more progressive) start to my mower but it still gives a shock . I do not know if that can be put on yours?? But the best way is to start it at the lowest iddle possible ( in my case) . Good luck. Roger.
I put a photo, it is the amber yellow square button left of the yellow pto switch on the right side of the steering.
/ Violent start of rotary cutter #26
Well, ya put your steering wheel right over that magic switch! I figured someone would have some sort of 'soft start' switch or setup by now. Good info....bad pic. (of the button) ;)
/ Violent start of rotary cutter #27
As you said , good info bad pics... nothing is perfect:laughing:
I had taken that photo a few month ago and used it today. But at least you got the idea :D. Have a nice day sir .
/ Violent start of rotary cutter #28
On my Montana if you load the hydraulics up with the loader curl it softens the blow allot. Just curl the bucket all the way up and hold the pressure against it, then engage the PTO.
/ Violent start of rotary cutter #29
Sounds to me like another potential good idea. I only say 'potential' since I can't try it out. Being wimpy and afraid of breaking my 50 hp rotary cutter gearbox with 78 PTO hp, I went with the old fashioned manual lever. :eek:
/ Violent start of rotary cutter #30
Can't hurt to give that a try next time I have the cutter on.
/ Violent start of rotary cutter #31
i have a heavey duty lands pride i bought with my dk45. when the dealer brought out i ask him about it and he smiled and said hey its under warrenty start slow and it will be just fine. It's a tractor not a B.M/W.:laughing:ive been mowing so many rocks and hidden stumps lately that it dosent bother me any more:ashamed:
/ Violent start of rotary cutter #32
i had a dk55 and a bush hog 305 heavyduty rough cut mower, that tractor destroyed that cutter, twisted the pto 3 times and it never broke, replaced that with a modern shaft and slipclutch. the thing alway engaged hard, thats the major flaw in all kiotis with the electro engagement of the pto. pushing in the clutch should in my opinion over ride all driveline systems. i never really did get use to that part of it, even at idle its still a jolt. i sold mine and don't think i'd buy another one just for that reason, to many good used tractors out there for that.
/ Violent start of rotary cutter #33
I'm a bit late joining in on this one.
But I will echo the comments that a slip clutch does solve this problem to a large extent.
Your all missing the point so far re the slip clutch :cool:
The slip clutch should not be so loose so as it slips for more than a second on startup.
When the blades are stationary, they are folded in funny positions out of balance, and there is a massive amount of torque required to get that initial bit of spin on them. That first jolt to get them to spin and throw the tips out is what starts the machine vibrating.
If you have a slip clutch, as the PTO bangs in, the clutch will absorb the first half a second or so of it, and start the blade spinning and get the tips flung out. Only just so as the blade is moving - and then it will be tight again and the blades will get up to speed.
You can prove this concept by starting the PTO, turning the PTO off, waiting for the blades to almost stop, and then start the PTO up again. It will be much smoother even with a very small level of pre-rotation.
This concept is well known in the full size ag machines, we run two big square balers making bales 3 foot x 3 foot by 7 foot long, with a great big plunger that shoves the grass back through the chamber.
The manual specifies that everytime the plunger goes to the end of it's stroke, the slip clutch should move about 1/3rd of a turn, and you can observe this happening. It takes some of the shock out of the driveline.
When you start the baler up the slip clutch will slip for the first few turns and then catch up with itself as it all starts turning.
Most big tractor nowadays do indeed have a slow start, taking about 3 seconds from very slow to ramping up. Just a matter of filling the clutch packs up slower.
But some machines still manage to stall the tractor the resistance to start turning is just so great. Two solutions we use to help this, one is to let the clutch out in a high gear just as you are about to engage the PTO to nearly stall the tractor which drags the RPMs down, and then engage the PTO. Only works with gear tractors though.
The second method is to be lifting the loader or the three point linkage at the same time. The oil needs to be flowing into a cylinder so as it can't fill up the clutch packs so quickly. Dead heading it against a cylinder as mentioned in this thread already won't do much (no different to having the valve shut in terms of oil flow).
/ Violent start of rotary cutter #34
The cutter blades are getting crossed when it is stopped and when you restart, it takes a while to throw the blades out to operating position. Always start slowly at lower RPM and with the cutter slightly off the ground. Sounds like the tractor PTO is kicking in very abruptly. Ken Sweet
Ditto; same on my 4' KK hog, it is the blade stuck at an angle and until centrifugal force straightens it out it'll vibrate the fillings out of your back teeth!
2004 Ford F-150 Ext. Cab Pickup Truck (A59230)
2004 Ford F-150...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2013 Keystone Laredo LA329RE13 37ft. T/A Fifth Wheel Travel Trailer (A59231)
2013 Keystone...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
