Need help configuring a Kubota M6040/7040
   / Need help configuring a Kubota M6040/7040 #1
stsimon
I really appreciate the knowledge and experience of the folks that post here, so I am asking for some help in configuring an M series.
I have 42 acres used for breeding a few horses and keeping bees in central Kentucky. Hard to believe, but for several years I have mowed this property with a Kubota ZD21 with a 60 inch pro deck. It works great when I can keep up with the grass, but that almost never happens. It is good around trees and many tight areas that I need to get into.
I am looking to buy a M6040 or M7040 to pull a Bush Hog 2212 or similar 12 ft Rhino bat wing. Eventually I would like to add a Rhino 1400 boom flail for mowing on the dam, pond and creek banks. I have no need for a FEL. On the rare occaisions when I need to push dirt around I can rent a Bobcat.
I am thinking of configuring as follows: Turf tires, filled rears, cab 2wd ( I don't need to work in the mud), 5 front weights, block heater. I don't know how to configure the hydraulics. I may need other things I am not even aware of. Any ideas are most welcome.
Thanks in advance.
Tom Rossman
   / Need help configuring a Kubota M6040/7040 #2
I am in the beginning stages of configuring an M7040 or M8540, so I will be interested in your responses. I am presently using a Case CX80 and from my experience Ag tires are needed for me as I have some slopes. Four wheel drive is also necessary, not because of mud, but when backing up hills/slopes. I was mowing with my Woods DS1260 yesterday and neglected to put it in 4WD and was quickly reminded why I have it.
I have access to a 864 Bobcat as well as track hoe, but can't stand the thought of not getting a FEL, but that is just me.
I am still researching my hydraulic needs.
Good luck and I will read with interest.
   / Need help configuring a Kubota M6040/7040 #3
Welcome to the forum!!!! I am kind of surprised that you don't need a FEL and have horses. It sure would make manure clean up and feeding hay easier. I would get the 3 rear remote option. Don't boom mowers use 3?
MarkV
Mark,
In our management process the horses stay out all the time unless they are sick or the weather is really bad. They have a large covered run in area. They don't really generate enough manure to justify the high proce of a loader.
I don't know what the boom mower needs, I am hoping someone else will.
   / Need help configuring a Kubota M6040/7040 #5
Another plug for a FEL. Once you have one you will find all kinds of uses for it. It is one of the things that I can not do without on the ranch.
Partial list: (others will add)
Tool and equipment tote
Driving T-posts
Lifting heavy stuff (Bobcat welder into truck)
Handling round bales
Pushing yourself out when you get stuck
Back-dragging to level dirt, gravel, etc.
   / Need help configuring a Kubota M6040/7040 #6
I just bought an M8540 a few weeks ago. I spent 6 months exhaustively researching the entire M and MX line. If you have any questions, feel free to ask. Obviously I think the M8540 was best... but I almost have the specs of all the M tractors in my head. I can help with some of the details if you want.
   / Need help configuring a Kubota M6040/7040 #7
I'm with the others on the loader. but about your tires, you won't need mud to get stuck with turf tires, your 42 acres of grass will get you when its wet.
   / Need help configuring a Kubota M6040/7040 #8
Thanks, I am in the beginning stages now as I really hate to get rid of my CX80, but it is just no longer dependable.
I am definitely going to get a cab, FEL, AG tires, rear remotes, just don't know what kind, looking seriously at hydraulic shuttle as I have little use of my left leg and need to cut down as much as possible on clutching.
Most of my use is bush hogging with a Woods 121 3-point and DS1260 pull behind, pushing brush and dirt etc. We quit farming years ago, so we just do some small food plots. We have around 500 acres spread out, but have other tractors, so it won't have to do all the "work".
I am running some stuff on the Kubota "build" section.
   / Need help configuring a Kubota M6040/7040 #9
Here are a few things to consider:
3 rear remotes - you can never have to many. They come in self canceling and float valves. Float would be useful on a batwing bushhog just leave the hydraulic valve in the float postion to allow the wings to follow the contour of the ground without any pressure on the hydraulic cylinders. Self canceling is good when closing the door on a round baler you can just push the lever all the way and let go and when the door is closed all the way the lever will return to the neutral position. These are just a couple of examples.
4x4 - used more then you can imagine my last 4 tractors have been 4x4
Cab - makes it really nice and comfortable in all weather conditions and provides protection from bees. I have hit several hornet nests over the years bushhogging and since I got a cab its not a bid deal.
FEL - used more then you can imagine. If you get the skid steer hookup on the FEL you can rent attachments for a skid steer almost anywhere. I would get the 3rd function valve on the FEL to allow the use of post hole diggers and grapple buckets on the front just to name a few options.
M8540 or M9540 - if you could move up to the 8540 you can get the 12 speed trans. To me on the 8 speed trans the gears are to far apart and will force you to go slower or faster than you wish in some situations.
Tires - on a 42 acre farm I would think the you would be better served with ag tires on the tractor and use the mower around the house and the tractor in the fields.
The above is just my $.02 from my past experience and what I need in a tractor. Take it with a grain of salt. Everyone makes their on money and should spend it how they wish.
This is what I bought a few weeks ago:
I just bought a M9540, 4x4, Cab, 12 speed Hydraulic Shuttle Shift, 3 rear remotes (2 self canceling, 1 float) and Front Loader with 3rd function valve. I never had a FEL on a tractor until I bought a new tractor in 1997. This is the 3rd tractor I have bought since then and all have had front loaders. I also have a Bobcat to use around the farm and still bought one. I bought the FEL on my Kubota with the skid steer hookup and I am able to use all the attachments I have for my Bobcat on my tractor.
I think I will go with the Ag tires after all. Great information on the remotes. Also excellent idea on the skid steer hookup, I had not been aware of that. The challenge will be the price of an 8540 if I go that route.
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
PALLET OF TARPS, UMBRELLAS, AND PORTABLE SHADES (A50854)
PALLET OF TARPS...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
