Undecided..Is this a good deal, JD 5325
   / Undecided..Is this a good deal, JD 5325 #1
rutwad
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
I mentioned on another thread I was looking for a Kubota M5040. IN my search, I found a JD 5325 that I like. I want to know if you guys (gals too) think this is a good deal or not.
2007 JD 5325
Cab
Air Seat
12/12 pwr reverser
540/540e PTO
2 Rear SCV
No loader or joystick
Electro 3 pt hitch
Front fenders
Rear Fender extensions
R1 radials, 95%
Less than 100 hrs.
JD MX7 rotary cutter, dual wheel option- Bought new with Tractor
BH SBX 840 Box blade w/scarifer teeth
$35,000
   / Undecided..Is this a good deal, JD 5325 #2
If you can put it to work on your place, and like it....sounds like a good deal for you. Do you plan to add the FEL to it?
Would like some pics.
Curious about the "Electro 3 pt hitch" :confused3:
I may have miscalled it something else. It's the EH Hitch, (I think).
No plans for FEL. Backhoe available for that.
   / Undecided..Is this a good deal, JD 5325 #4
Wow! Sweet rig. :cool2:
Color him green :D
   / Undecided..Is this a good deal, JD 5325 #5
First off that tractor doesn't look worse for wear. Very nice tractor with a new MX7 and box blade to boot. About the same hp and price as a new 4720 after discounts. The implements would not be included with a 4720, but that price is about right with full weights and other options.
   / Undecided..Is this a good deal, JD 5325 #6
Nice looking rig. My son bought a new MX7 last year at $3500, if that helps value the tractor deal? Ken Sweet
   / Undecided..Is this a good deal, JD 5325 #7
Rereading my last post I thought I should clarify that the 5325 is a nice tractor. I would have been more interested in something similar if it were not for sharing equipment I already had, plus the fact if I do need to get something new for ranch work it would need to be a minimum of a 6000 series. Overall I would feel for most work that 65hp 5325 is an optimum sized tractor that can handle many tasks.:thumbsup:
   / Undecided..Is this a good deal, JD 5325 #8
Very good lookin' tractor! I see the light package, rear wiper, too. I believe that with the EH hitch you have an electric switch mounted on the rear fender that you can raise and lower the 3pt from the back of the tractor when attaching/unhooking implements.
Very handy!
Does it have the adjustable Power Modulator for the reverser? (Good thing to have if you ever get a loader for it.)
AKfish
Thanks everyone!
Trying to get shipping quote, anybody know the height?
   / Undecided..Is this a good deal, JD 5325 #10
It appears to be a fair price both ways. My JD5325, sans cab, has been a real workhorse at clearing overgrown fields, turning forest into fields, and grooming roadways. When my pasture is turned to vineyard I'm seriously thinking of finding a narrow version. My only hesitation is I prefer less ground pressure through the rows.
1998 Ford F800 2,000 Gallon Water Truck (A49461)
1998 Ford F800...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A49461)
2012 Ford F-550...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
