while doing various chores around the Homestead much of the time I will need maybe 5,10,15 minutes to accomplish a task. Should I leave the K B7800 running or turn it off and re-start it. In the long run is it better,worse, or does not matter to the Engines well being?
I can certainly see that, esp in cases of precarious parking or mobile implements left running. In the cold light of day tho I have to consider the times we use tractors to apply stationary power without a bit of worry about the tractor itself doing anything unpredicted. -- PTO gen, pump, hay elevator, wood chipper, post driver, ... etc. How can this be any different than getting off a parked idling tractor? Quality of the parking job is the only thing I can see.:confused3:Mechanical issues aside, I just can't get comfortable dismounting a tractor while it is running. I realize it can be done safely, but old habits die hard or in some cases not at all.
larry
Is there an argument? Is zero risk the necessary criterion? Theres no way to get anything done then and that, in itself, is risky.I agree with Triple R - There are a lot of things in life that you can get away with 9999 times but at 10,000 there is a mega price to be paid - True too in driving - You can run for years not leaving enough space between you and the car in front of you but the time you "pay the piper" sucks!
Is there an argument? Is zero risk the necessary criteria? Theres no way to get anything done then.
larry
@BruceWard: Some reading I did (Four Stroke Performance Tuning by A Graham Bell) suggested that coolant temperature increasing after an engine stops is normal.
There's the issue of cylinder wash....I have nothing to back this up but it's generally accepted that diesel engines stand up to excessive idling better than gasoline engines do on account of cylinder wash, isn't it? On the subject: I once heard a fellow from Caterpillar say to avoid extended idling but if an engine needed to be left running for extended periods, to "bump the rpm's up a bit"
For me, a big part of it is how hard it is to start the equipment and how hard the engine was working in the minute leading up to the stop. If it needs a lot of cranking I'm more inclined to idle the engine for short stops and if it's been working hard I'll let it idle for a minute or two before turning it off.
My Chevy welding truck kicks over in an instant and I have no issues with killing the engine for the shortest breaks.
Of course, on cold days....
It doesn't bother my sons a bit as all they have ever used is modern equipment with brakes that actually work, safety switches etc.
For me getting off is not an issue - but more than once getting back on I have swung my leg over the tranny case and accidentally put my foot on the GO pedal. With an HST its always "in gear" so the tractor lunges forwards and the brakes scream (I almost always put the parking brake on). One time... it really did get a bit ugly as I was standing in the saddle when my foot hit the go pedal. I'm more careful now... but the HST really makes it easy to be complaisant!
