New Cherry Picker
/ New Cherry Picker #12
Nice set up Timber. I have been going to do something like that for a few years now and never got one of them "round to it things"! I like your idea better then what I had planned.
/ New Cherry Picker #13
Looks good, but be sure to add LOT'S of weight to the front of the tractor!! I can easily see the leverage factor tipping the front end up into the air. Also, considering the size of the steel frame the picker is made with, that little drawbar it's bolted to looks pretty skimpy. The drawbar's greatest strength is in the horizontal plane as in pulling heavy loads, not vertical as in supporting heavy loads. It should work fine though as long as you don't ask too much of it.
I would be worried about the drawbar failing. The torque multiplication from the long moment arm is going to put a lot of force on it. Might be fine, but keep an eye on it just in case!
Ford Tractor
/ New Cherry Picker
Ford Tractor
I am not that concerned about it. I am considering a set of wheels under it. I put this together for a specific task. I am setting large stones into place in my water garden. I find it unlikely for the draw bar to fail but anything is possible.
/ New Cherry Picker #16
i stall my rockshaft trying to lift things off a drawbar like that, and my tractor supply cheepie hasnt complained yet. i thuink youll be fine
/ New Cherry Picker
I think I am going to make a dolly wheels for this application. I will modify a large swivel caster to these wheels and mount it under the draw bar
/ New Cherry Picker #18
I'm not the greatest welder but that doesn't stop me from making stuff
Nice work....Hey, my dad always said, while its good to get an education, there is no replacement for hands on. Talking or reading about welding wont make you better...but burn 100lbs of rod and you'll get the hang of it:thumbsup:
/ New Cherry Picker
Well I am almost finished with the mods to the cherry picker. I added some chains and turnbuckles to support some of the side to side movement
I modified some caster wheels to help support some of the wt moving some of the loads around. I have 1 more to make for the other side
/ New Cherry Picker #20
2025 MMS MS36C (A53317)
2025 MMS MS36C...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
1999 Ford F-150 4x4 Pickup Truck (A61568)
1999 Ford F-150...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2020 Bobcat E35 (A60462)
2020 Bobcat E35...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
