kioti ck 30,rears15-19.5,,ind, 6ply,18 -19 psi loaded with methinal,,,,front[without a loader],25x8.50-14,ind.,6ply,28-30 psi,you need more if you got a loader on it...
Book says,30 rear,50 front,titan tire[after communicating with them] agrees with my settings,they just gotta go with the same safety stuff,watch your lawyer stuff that my copenhagen can says in owners manuals...
So,you can run about 18-19 lbs in rear,no matter what,,front tires pressure depends on loader,and than,loader use..
If I had a loader,would be running about 50 psi in front..You could probably run 10 psi in rear and 20 in front,if you didn't have a loader or spin your tires a lot under heavy load.
