1000 Hours and counting
/ 1000 Hours and counting #1
stray
east TN
Power-trac 422 2003 model and 428 January 2015 model
I now have over 1000 hrs on my 2003 PT422 Robin. The only 2 problems were a fried voltage regulator and a bad coil. O yes I had to weld and brace the pivot, rollover, lift bar but that was easy. Replaced the battery and tightened a few fittings. I am well satisified with the tractor and engine preformance. It still runs as strong as the day i got it. what a machine!!!!!!!
/ 1000 Hours and counting #2
Stray thanks for posting your 1000 hour mile stone and it is still running strong. I hope you get many more trouble free hours on it.
I forgot to mention a broken wheel motor but that incident was entirely my fault.
/ 1000 Hours and counting #4
I know what you mean those things sorta do happen, I busted the seals in the left rear wheel on mine. I had mine rebuilt wasn't terribly expensive.
/ 1000 Hours and counting #5
I have a little over 1,500 hours on my 422 and the only problems I have had are replacing the front hubs,(my fault not torking the wheel nut tight enough, which wore the key way) the front lovejoy coupler and rubber spider last year, and the ignition coils. Other than that just regular maintenance.
/ 1000 Hours and counting #6
That is a lot of hours for a small machine. Getting these types of hours is almost more a testament to the usefulness of the machine than it is the reliability.
That motor probably uses about 3 gallons of gas per hour, so that was about 3000 gallons of fuel. That fuel cost about $7500. Holy crap!!!:D Good reason to get the diesel right there, lol.
/ 1000 Hours and counting #7
Good point. How much less would the diesel use?
/ 1000 Hours and counting #8
Diesel will use 1 to 1 1/2 gallons per hour at full throttle.
Chris from Power Trac told me that the 1460 will run almost 8 hours on a 12 gallon tank of diesel, at full throttle. My guess is that the 30 and 45 horse Deutz's use less.
Diesel is a little more expensive, but it goes a LOT further.
/ 1000 Hours and counting #9
My 425 goes through about 2 gallons per hour at full throttle when mowing with the 60" deck. More like 1 to 1.5 gallons per hour with other, easier tasks while at ~75% throttle... Not too shabby.
/ 1000 Hours and counting #10
Yeah that's pretty good. My Deere zero turn has a 25 HP Kawasaki air cooled in it, and it uses 3 gallons per hour. I guess the double benefit of the diesel is that it doesn't run as long, because you are cutting with a 90" deck on the 1460. And it is only using 1 1/2 gallons per hour.
I have a big Deere 5520 that I mow the fields with, it has 75 PTO HP and cuts with a 15' rough cut flex wing mower. It uses about 2 gallons per hour at full throttle. Diesel is always more efficient.
/ 1000 Hours and counting #11
My PT425 uses nowhere near 3 gallons per hour. I have run it at full throttle for 8 hours on less than 10 gallons on several occasions. It is closer to 1.25 gallons per hour. ;)
/ 1000 Hours and counting #12
I also run about 1.5 gallons/hour when mowing...but, it's good to see 1000+ hours type of a posting as we seem to more often than not post when we have problems. With this many hours are you guys seeing any engine oil usage? I've noticed lately that I'm down about 1/4 qt at oil changes but I see no leaks.
/ 1000 Hours and counting #13
I figure I use around 1 gallon an hour on my 422 and on my 1845 I probably use a little less than 1 gal. per hour mowing. Neither of my machines seem to need any oil added between oil changes.
/ 1000 Hours and counting #14
I'm scratching 1800 hrs on my 425. Its 5 years old I think. I changed the engine at 1200 hrs. and have changed pretty much everything else on the machine. I think the frame is the only original thing left. It is used by my employees though. I was looking at it today and it has multiple leaks under the steering wheel that we can't seem to fix, but she keeps on trucking and while she's not as strong as she once was she is still useful for soooo many things.
/ 1000 Hours and counting #15
I bought mine used. At the time it had 1500 hours on it and I have put about 300 more on it. It was used by a landscaper before me. His employees were hard on things and this one has been on it's side once. Luckily I didn't pay much for it and I haven't had too much trouble with it.:thumbsup: As far as i know it is the original engine.
MF GC2300 fel replaced
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
