dash electrical 224
/ dash electrical 224 #1
TSMART
central florida
jinma jm 224
A few times in the last week my 224 (400 hours)...gages went dead. Only thing that works is the amp meter.....
No fuses blown.
Then the gages come back. This has now happened 3 times. Should I suspect the (original equipment) ignition switch here? Or is this a ground issue? Please educate me.
/ dash electrical 224 #2
I would check the grounds. Does it start fine using the key? Check all plugs under the dash also. I think you will find a loose connection in a plug or on a ground.
While you are at it check the battery connections. Don't just look at them. Take them apart and clean. Even the connection of the main ground wire to the frame and the connections at the starter. The connections at the starter power the fuse panel and inturn all the gauges.
Chris
Yes, it always starts fine using the key. Thanks.
/ dash electrical 224 #4
Cluster panel? or individual gauges?
//greg//
/ dash electrical 224 #6
Ok. Not sure about your specific cluster, but mine have 3 connector plugs pig-tailed off the back. One is the ammeter and ground wire. The other two are for gauges and indicators. So first thing I'd do is pull the cluster, then inspect and reseat the connectors.
//greg//
Thanks, Greg. Wasn't there a link a while back on how to pull cluster?
/ dash electrical 224 #8
There are 4-wing nuts,and 2-c-type clamps that hold it in,you will have to reach in on top of the fuel tank,you can prob.get it out without unplugging all the wires,check all the pins inside of the plug ins,you prob. have one that is loose.If all connections are good you might end up getting a new instrument panel
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
/ dash electrical 224 #10
Hi - you should look carefully at the fuses if you have the original fusebox. If it it is similar my Kama, the gauges are powered from the switched hot from the ignition switch through a fuse then to the gauge cluster. I ended up changing out my fusebox with a Buss unit that takes an ATC type fuse. Same one that Rob used on his Kama. He wrote a thread about it. In my case, I haven't had a bit of trouble since then. But, they acted the same as you are saying before I did the change.
regards
Curt
A couple years ago, I had a blown fuse. The others looked pretty cheap though, so I replaced them all. I can say that the fuse box (fuse bar?) looks pretty tired. The contacts look like old aluminum. One on a 15 amp fuse is bent pretty badly. And, though my reported problem is with these gages blinking out, I can say that the horn does not work, the lights work sometimes. Work light (to rear) does not work. Flasher does not work. Yet these fuses are not blown. I dont care so much about those problems tho they may be related....but I can't go with out temp gage for sure.
I guess I will remove all the fuses, hit them with some cr666 elec lube, and see if that does it. I keep the engine bay pretty clean. I have not yet had time this week to pull the cluster to reseat the connectors . In my wildest dreams I could get everything working again, even the horn.
On a really hot day, while mowing the field, I would drive by the house, honk the horn, wife comes out with a cold beer. I miss that horn. : ( Help me fix that horn. Please.
If I have to go replace the fuse bar, how does that work? Does the fuse bar plug into the harness? Is there extensive re-wiring for that job? Not a pro here by any means.
/ dash electrical 224 #12
No, its not hard at all. But unless you just want to replace your fuse box anyway, you need to make sure that is your gauge problem. Sounds like the same fuse box to me. Rusty aluminum colored fuse prongs. With my key on and the gauges not working, I wiggled the fuses until I found which one would make them bounce on and off. The basic wiring on mine was the main power to everything came in on a 10 or 12 gauge wire starting at the battery connection on the starter to the fuse box through a 30 amp fuse then out through the amp meter to the ignition switch. From the ignition switch another wire came back to the fuse box. This is the switched power that powers most of your stuff. Lights, gauges, horn everything that works with the key on. That wire supplies power to around 3 more fuses. One fuse just had the supply to the alternator field. Another had the horn and headlights. Another had the turn signals and work light. I put the gauge cluster wire on with the turn signals and work light. Like I said, I bought the fuse box Rob used. I bought it from Fuse Blocks and Fuse Panels. I used some flag style wire connectors from McMaster Carr. The Chinese fuse box used crimp on ring style connectors you run a screw through. The new one uses push on wire connectors. Buy some 10-12 gauge and some 14-16 gauge. You will have to use the larger 10-12 gauge ones with the main power wire and when you jumper wire in your new fuse box to crimp 2 wires in the same terminal. This is to use the same wire to power more than one fuse. The rest are the 14-16 gauge. Remember on the output side of the fuse you will have to combine all the stuff you want to run off that particular fuse into one wire connector. Another use for the 10-12 gauge wire connectors. The Chinese wires all have separate rings crimped on each wire. But you get to throw however many you need under the same screw. The fuse box itself fits right in the same hole the Chinese one came out of. Just drill some new mounting holes for the new one. I used spacers underneath my new box to bring it out to the same level as the tractor sheet metal. There is a ground wire there too in the fuse box area. Make sure and sand off the paint and reattach so you get a good ground.
regards
Curt
/ dash electrical 224 #13
Oh yes, I forgot to say I did have trouble with the screws just being loose on the original Chinese fuse box. Make sure the phillips head screws on each end of each fuse that secure the wires are tight. I get to thinking about all the trouble I had with the original, and may be you should just change it.
regards
Curt
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 Chevrolet...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2017 Dodge Charger Sedan (A64557)
2017 Dodge Charger...
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
213137 (A64276)
213137 (A64276)
