Tires how long did your factory tires last????
   / how long did your factory tires last???? #11
I would be interested to see a pic of those tires!
J
I'm off to the farm for two weeks on Saturday. I'll post pics on my return. I should have pointed out that my tractor is 2WD, and I use it mainly for bush-hogging.
Steve
Steve
ok.. Yea-- I have heard some R-1s that are dirt/hog tractors last almost to dryrot age..
J
   / how long did your factory tires last???? #13
I hear ya... what did you think of the pics I posted?
J
Your pictures illustrated what you needed them to. How long have you had your tractor? Mine is 4 yrs old. If I keep on going at the current rate, I'll need a set of fronts in 4-5 yrs, and maybe a set of rears in 10 yrs. I can live with that. Now if I get a 2nd (larger) tractor like I want to next year, with a backhoe I can spread the hours out a bit.... Will have to win over SWMBO first.:(
I got the tractor in Mar 2008...
J
   / how long did your factory tires last???? #15
My friend has an l3400 that is 1 yr newer than mine, but he has a lot of sand at his place. He has 50 more hours on his (I just turned 150 hrs) and they are just like new, so it does make a big difference.
yeah I hear ya...
on our property I have spun ALL 4 with the differential locked in gravel , sand, dirt and on asphault...
On one of the pics you should see a big gash from me getting stuck in the ditch.....
just curious how firm the rubber is...
J
   / how long did your factory tires last???? #17
8 hours and still going strong! He, he, he!
Of course, they do have cow pasture "stuff" on them. :D
   / how long did your factory tires last???? #18
I have about 240 hrs (somewhere close to that) on my bota 3400 and my fronts don't look bad at all.
I do a lot of dirt work and a good bit of highway pavement towing the wood hauling trailers. Maybe 20 or so trips to the woods per year which is 6mi round trip for the last 3 years. so about 180 highway miles from that and probabally another good 50 miles highway doing this and that. (In 2wd though).
Loader is almost always on, and I only ocassionaly use it to mow. It is used a lot in the woods when cutting and other than that, just maintaining my 5 acres with a creek/ditch that runs through it. Which I have re-done twice. And maintaining the gravel drive, digging seceral stumps with FEL, a 3000 gal fish pond, just the usual.
I'll go out and take some pics but they aren't anywhere close to the OP's.
   / how long did your factory tires last???? #19
I had to replace my fronts after 900 hrs. Not due to wear but due to the fact that the sidewall blew out on one of them. I can use the second for a spare in a pinch, but I didn't want to change only one.
   / how long did your factory tires last???? #20
Pictures. 243 hrs on the clock. I had to get a screwdriver and knock some mud off of them.
2019 BRADCO/PALADIN 116720 FORK CARRIAGE (A51243)
2019...
AGT Industrial Planter Attachment (A47384)
AGT Industrial...
UNUSED JCT DUSTLESS BLASTER (A51244)
UNUSED JCT...
8x18 Metal Rack Hay Wagon (A50774)
8x18 Metal Rack...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
1998 CATERPILLAR D250E OFF ROAD DUMP (A51242)
1998 CATERPILLAR...
