Bypass 445 safety switch?
/ Bypass 445 safety switch? #1
xrjohndeere
Gold Member
Mo
2021 Kubota L4060 HST
I have the 445 mower with the safety switch the shuts the mowing deck off if you try to back up without pulling up on the yellow pto switch.. Does anyone know how to bypass this so I can just back up while mowing without the hassle? I know this is a safety item but it is a pain in the a--. Thanks.
/ Bypass 445 safety switch? #2
I have the 445 ztrac too but I'm not sure what you're asking. Do you want to bak up while mowing? Mine is a 2009 and I can do that.
Rob
Mine is not a ztrac. It is a 2000 lawn tractor. All wheel steer.
/ Bypass 445 safety switch? #4
Not sure how to find the correct part #, check with dealer maybe. Some of the older versions allowed operation in reverse. I had a 99 that had that problem. Currently have a 96 and no problem.
/ Bypass 445 safety switch? #5
I have a 2001 and it mows in reverse. The sad part is that I cannot remember what, or if, I did anything to make it do it.:laughing: My memory is not that bad, its the recall part that is starting not to work......
It should be an easy find. The PTO stich must send a positive signal to something to allow it to over ride the shutoff. Jumper that wire and you are in business.
Thanks for the help.
/ Bypass 445 safety switch? #7
It's call a RIO switch I call it a PITA switch. I f you remove the seat and rear fender 4 bolts and you will need to remove both pedals 4 more bolts and mounted to the frame rail below you reverse pedal there is a switch and a plug you can't just disconnect it, it is part of the circuit you need to jump the switch with a small piece of wire. Tape it up and wire tye it down. Some people just move the switch out of the way of the pedal. If you blow snow it must go.
This is a taboo subject on other tractor forums so be careful not to back over anything when you bypass the switch.
/ Bypass 445 safety switch? #8
Just crawl under when you have the mower deck removed, and you will see the switch that needs to be disconnected (jumpered). Not necessary to remove the rear fender and pedals, unless desired.
Easy to track it down by moving the reverse pedal.
Some dealers feel they have to put these safety switches back in working order if they have your tractor in their shop. Claim (or their insurance dictates) they could be held liable if they don't do this and something happens. So ask, and if so, do that chore so you don't get charged for it.
The other "fix" I did was add some height to the reverse pedal, so going in reverse wasn't so slow.
/ Bypass 445 safety switch? #9
The forward and reverse pedals are connected to each other, as you know. So when you use reverse, you and lift up on the forward pedal with your foot and it will go the same speed in reverse as it will forward.
/ Bypass 445 safety switch? #10
On the tractor I have now no way you can see it looking under tractor they put the switch in the u-channel of the frame rail. Maybe on some models you can see it.
/ Bypass 445 safety switch? #11
I have an lx277 with the round yellow knob for pto engagement. You have to pull up on it to keep blades running when backing up. To solve this I simply clipped a clothes-pin under it to hold it up all the time. Works perfectly.
/ Bypass 445 safety switch? #12
I've crawled under the 425's, two 445's, an X485, and my latest 455 to disable the RIO.
The X485 was the most difficult to disable, but gotRdun. :) I'm thinking there are plans afloat to make it more and more difficult to over-ride this feature.
Didn't have to go through any trouble except removing the mower deck from under the tractors.
/ Bypass 445 safety switch? #13
You answered your own question; it is called a "Safety Switch" for a reason. The lawyers had it installed to protect the company from YOU doing something stupid.:eek:
/ Bypass 445 safety switch? #14
I would be surprised if there weren't. Coworker's dad got a new JD combine. It has a similar switch to prevent running the PTO for the head while not in the cab. They disabled it as normal however it only briefly worked. They suspect they are building some sort of resistance in the switch now so if you jumper it, it still won't work.
/ Bypass 445 safety switch? #16
I think your right on about the CO. they are worried about what I call the idiot factor (People with no common sense). If they are that bad a driver put a mirror on it. but of course they won't use it. to lazy to look. I grew up on a large farm and know of a lot of stupid stuff one getting in a feed wagon with it running and getting a spike in the thy and another where he go sucked in the auger (Died). these were both freinds on other farms. Like the combine, cleaning a plugged head with the engine running (Dumb)!!!! An osha inspector that got his ear taken off by a PTO, And this was our inspector! And they think he is smart enough to figure out what is safe, (NOT)!!!!!!! The main thing is think before you do stuff, What will be the result? you are only as safe as the operator.
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2006 John Deere 1600 Turf Mower (A63116)
2006 John Deere...
2010 Ford Mustang Convertible (A61569)
2010 Ford Mustang...
Eagle Weathervane (A61569)
Eagle Weathervane...
2025 Electric Cart (A61569)
2025 Electric Cart...
