Hydraulic Leaks
/ Hydraulic Leaks #1
BuzzyG
I am working with a Ford 445 backhoe. It is one stroooooonnnnng machine.
I have a growing leak around the shaft of my front mount hydraulic pump. Are any of the stop-leak fluids worth considering?
Thanks
/ Hydraulic Leaks #2
Gday Buzzy save the money you would have spent on the stop leak and put it towards replacing the seal in the pump.
Jon
/ Hydraulic Leaks #3
Jon
+1 on this
Also check to see why the seal is leaking in the first place.
Is the drive coupling out of alignment causing the shaft to wobble slightly?
If this is a pressure compensated pump (cloesed center system) it will have a case drain line on it. Make sure this is not obstructed in any way. Excess pressure on these will cause the seals to leak.
/ Hydraulic Leaks
Thanks for the reply. And your suggestion is my first impulse as well, but I cannot find the seal or the exact pump that I have.
Further - according to all of the documentation I can find, the pump does not seem to come apart to allow servicing.
That is the reason I became curious about the other solution.
Is it possible that the seal drives in from the exterior without disassembling the pump?
/ Hydraulic Leaks #5
I just did a search and found a sight that stated the 445 had "open center" hydraulics so the pump is probably a gear type. so yes, it is possible that the seal can be replaced witout dissassembling the pump.
Roy
/ Hydraulic Leaks #6
it was put togehter.. unless it is hermetically sealed.. it comes apart.
the seal can be replaced by matching ID of housing, OD of shaft, and width of seal, if you need a generic.
check bushing or beairng as well.. many times seals fail due to a worn bushing or bearing or shaft that is running out of alignment.
soundguy
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
Mini Bucket Excavator Attachment (A61572)
Mini Bucket...
POWELL / COLE 6R RIPPER (A63291)
POWELL / COLE 6R...
John Deere 410D Backhoe (A62679)
John Deere 410D...
2019 GREAT DANE CS1-1314-21053 53X102 DRY VAN TRAILER (A59912)
2019 GREAT DANE...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
