barbqranch
I don't know what the "proper" answer is, but I always slow the engine down to an idle before engaging the PTO. Seems less stressful to me, at least on the clutch. Yes, you do have to push the clutch in.
Just curious, my TC30 has a lever on the left side for the pto, and I still need to disengage the clutch, or I thrash gears. The transmission is hydrostatic fwd/rev with a geared hi, med, low. So you can just shove the pto lever forward and it just smoothly engages, even at full rpm?
Although I've had my TC40DA for 5 years, I've never used my PHD much, until the latest fence building project. I've only dug 2 of the fence post holes, but it wasn't a lot of fun. On my old tractor, I had control of the PTO with a foot clutch, so had my hands free to guide the tractor and work the 3PH. With the new tractor, I have the PTO lever on my left, the 3PH lever on my right, the wheel in front of me and the PHD behind me. I feel like I need a 3rd hand!
What I am doing now is guiding the PHD into position, putting my foot firmly on the brake. I then lower the 3PH to the ground. I have to turn back around, take my left hand off the wheel and engage the PTO. I quickly turn around to watch what is happening and to raise the 3PT at the right moment, then quickly turning back to the left so I can disengage the PTO. I feel like I'm doing a very bad dance and it also feels a little dangerous.
Am I doing this correctly and do I just need practice, or is there a better method?
Thanks,
Montejw, Chris's (DocHeb's) description is exactly correct. Our Class III Boomers with HST transmissions are unique in that they do not have a transmission clutch. The engine is directly coupled into the transmission. When you allow the HST pedals to come to neutral position, you can change transmission ranges because there is no engine power coupled through the transmission. As long as you don't press on the forward or reverse HST pedal, there will be no gear grinding when the ranges are changed.
Here's the difference, I have to use the clutch for the pto, whereas the clutch for yours is actuated by the lever evidently. So both tractors have a clutch for the PTO, one is foot actuated, the other is hydraulic.Now, completely independent of the HST transmission, there is a shaft that drives the PTO. This PTO has its own clutch that is engaged with hydraulic pressure. When you move the PTO lever to engage, hydraulic pressure is allowed to cause a PTO brake to release and the clutch to engage. If the tractor's hydraulic pump fails, the PTO will automatically disengage because it loses pressure. We normally lower our RPM before engaging/disengaging the PTO because it saves the hydraulic clutch. On a small device like a PHD that has very little inertia, you can disengage the PTO and it will stop almost immediately. If you have something like a rotary cutter, it takes a few seconds for the PTO to stop. The faster it is going, the longer it takes. Lowering engine RPM is the best way to ensure your PTO clutch and brake will last a long time.
I'm wondering if the clutch on the TC30 is actually for the transmission, I'm thinking not. It's just for the PTO. Or at least that's the only time you'd ever use it. At least that's my experience.Many/most HST tractors have a regular clutch for the transmission, but this is not true for the TC35/40/45 Deluxe model tractors. If you own a tractor like the TC30, you can easily get confused by our discussions. On all tractors, lowering engine RPM to engage/disengage the PTO is a good idea whether the tractor is a fully independent PTO or not.
...The other advantage of running slower is that you will never experience the joyof "augering down" - where the auger suddenly gets a really good bite in the soil, or threads around a larger rock or root. In ten turns of the PTO the auger will screw itself completely into the ground. If your PTO is running at 300 RPM - this will happen so fast you will not be able to react. Then you will find that your 3pt will bypass when you try to lift the auger out of the hole. You will have to disconnect the drive head and use a really big pipe to unscrew the auger from the ground. You will only do this once.
