Aftermarket suspension seat
   / Aftermarket suspension seat #1
RayK
Member
Ontario Canada
Kioti CK20HST-Kubota G1700
Has anyone installed an aftermarket suspension seat on the older CK20, I'm looking for a reasonably priced replacement, which one did you use and how do you like it Thanks Ray
   / Aftermarket suspension seat #2
I can tell you that I tried with a suspension seat from AgriSupply but could not get it to fit properly. Bummer as Kioti charges about $500 or possibly more for the new (since 2006 as I recall) suspension seat.
A cheapo easy fix while you are looking for a reasonable suspension seat is to take an inner tube for an 8 or 10 inch tire and partially inflate it then stick it under the seat. Sounds odd but it actually made a big difference.
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
Ford Pickup NR (A50323)
Ford Pickup NR...
