Cub Cadet 7200 Backhoe Not Working
   / Cub Cadet 7200 Backhoe Not Working #1
Rastafunk
I have a 2003 Cub Cadet 7200 with a Woods 457 Backhoe. After a couple months of use, a line on the backhoe blew. I took the backhoe off in order to replace the hose and still be able to use the tractor in the mean time, and when I re-attached the backhoe, it no longer worked. I am not very familiar with hydraulics, but I know I hooked the lines up correctly. Any ideas why it no longer works? Do I need to bleed the system? Thanks!
   / Cub Cadet 7200 Backhoe Not Working #2
Rastafunk,
I am thinking your quick disconnects are not fully engaged. Then again, maybe a relief valve blew and stuck in that position.
hugs, Brandi
   / Cub Cadet 7200 Backhoe Not Working #3
There is no need to "bleed" the system, just moving all functions from lock-to-lock will do that.
Does the engine sound labored at all? Like Brandi wrote, recheck all the connection again.
   / Cub Cadet 7200 Backhoe Not Working #4
I would encourage everyone using hydraulics to install a hyd gage in the hyd system, to know what is normal and not normal.
   / Cub Cadet 7200 Backhoe Not Working #5
JJ,
That is a good idea, but how does it relate to his backhoe not working now?:confused2:
Brandi
   / Cub Cadet 7200 Backhoe Not Working #6
Because you will know when you have pressure to any circuit, and how much.
QD's unlatched could shut off pressure.
In a complete BH circuit, the fluid flows through all valves in line, including the BH control valve, and then to tank. If pressure builds up on the gage, when you move a BH lever, then you have pressure, hopefully enough.
   / Cub Cadet 7200 Backhoe Not Working #7
I've done this myself before. 99% chance of the quick disconnects not connected properly. They might LOOK attached....and FEEL attached.....but they're NOT attached.
   / Cub Cadet 7200 Backhoe Not Working #9
I should have said shut off hyd flow.
Mobile Military Generator (A48837)
Mobile Military...
2018 Dodge Ram 4500 4x4 Enclosed Service Truck (A48081)
2018 Dodge Ram...
INOP/NON-RUNNING 2012 Ford F-450 Pickup Truck, VIN # 1FD0W4HT2CEC31215 (A48836)
INOP/NON-RUNNING...
2006 Ford F-150 4x4 Pickup Truck, VIN # 1FTPW14V66FB02837 (A48836)
2006 Ford F-150...
UNUSED Life Proof SPC Luxury Flooring (A50860)
UNUSED Life Proof...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
