JD 346 Rebuilt
/ JD 346 Rebuilt #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am going to venture into a project. Has anybody pulled the plunger out of these balers and done all the bearings and shimmed it, etc?
Thanks,
D.
/ JD 346 Rebuilt #2
Yes.
It's been a while since I have down one. It doesn't come out all that hard, need to remove the resistor plates, tie up the hay dogs and loosen the tension springs all the way off. I think thats about it, then it should slide right out the back.
I could be forgetting something, it's been a while.
/ JD 346 Rebuilt
Yes.
OK - I am going to dive into this baler and see what I can learn. I suspect it needs all new bearings on the plunger and probably guides. I guess I will know when I tear it apart.
Any good sources for parts besides my JD dealer?
D.
/ JD 346 Rebuilt #4
Bearings are bearings. Match them up and go cheap.
/ JD 346 Rebuilt
Once I get the plunger out I will have a better idea of what I am dealing with. I am assuming they are all shot - feels pretty loose in there.
D.
/ JD 346 Rebuilt #6
I now sometimes its a pain in the a**. But take some pics so we can join in your venture! I never know when I am going to get in the same situations:thumbsup: Good luck! Tell ya the truth wish I could help!
/ JD 346 Rebuilt
I just talked to a square baler expert. He told me to pop rivet some metal to it to keep the hay in the baler and go bale with it.
D.
/ JD 346 Rebuilt
I have been reading the tech manual. I think I will tear down the parts one first and learn on it first.
D.
/ JD 346 Rebuilt #9
D.
As long as it's whole in the areas coming apart that a very good idea. I say whole only due to if parts are missing you won't get the same experience until you tear into the good baler.
As far as the pop rivet idea, I would weld it. I don't think rivets will hold up as long or as well as weld. I have a friend that I have welded up his baler in a few spots including the area you have a hole. His wasn't as bad as yours though.
Good luck.
/ JD 346 Rebuilt #10
D.
Sounds like a real 'expert'. If it is like a NH baler, some of the plunger bearings can be adjusted to tighten up the plunger slop. Follow the manual, the info there will be better than the local sample you posted.
2022 INTERNATIONAL MV607 S/A 26FT NON CDL BOX TRUCK (A69167)
2022 INTERNATIONAL...
2027 . . (A67714)
2027 . . (A67714)
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
2008 WINSTON AP22024AL-DC EQUIPMENT TRAILER (A66091)
2008 WINSTON...
2015 INTERNATIONAL PROSTAR+ (A67714)
2015 INTERNATIONAL...
