Overheating problem
/ Overheating problem #1
Rich Waugh
US Virgin Islands
Jinma JM304
A couple weeks ago, I was mowing the orchards and the tractor overheated and blew steam all over. The **** regulator fuse had blown fifteen minutes earlier so I had no gauges and took a chance dumb, I know. Okay, I shut it down and cooled it off and added water to get back to the shop where refilled with fresh coolant. Started and ran fine. Then a major oil leak cropped up and I put the water thing out of my mind again, dumb.
I was mowing a few days back and thought it was running a hair warm. Stopped and cleaned the chaff screen and it cooled back to 80-85C and was fine. When I got back to the shop it was a gallon low on coolant and I could see where it had been peeing out the overflow. Topped it up and watched for oil, bubbles, etc. Looked okay. Developed a burst of delayed conscientiousness and torqued the head bolts - all seemed to take very little additional movement to get up to the recommended 125 #/ft.
Mowed again a day or two later and it got warm again. I was done so I just brought it in and put off the checking until the next day. It was down a half gallon. This time I topped it up and brought it up to heat until the 'stat opened and I could see flow. Flow was good. I could also see, when I first took the cap off, foamy coolant in the radiator neck. Blew the suds off like a fresh beer and watched a while - good flow, but it looked like the water is lightly "carbonated." Capped it off with my palm but couldn't feel any pressure building. Still, it shouldn't look carbonated, should it? I don't beans from barleycorn about diesel coolant or cooling systems, obviously.
No prominent signs of water burning, other than a slight bluish-white exhaust vapor during acceleration, particularly when cold. I do feel like the engine has somewhat less power than it did last month. Had to run some hills one gear lower than before, but that could be grass density, too. Still, seemed a mite wimpy to me for an engine purported to be 30 hp, but once again I have no real experience to draw on here. I did the injector checking thing and all produced the same drop when cracked, FWIW.
I'm coming to the conclusion that I may have a leaking head gasket. The initial overheating incident happened at about 80 hours, before the head was ever re-torqued and maybe that could have damaged the gasket? I could use some inspiration here from those who are rless ignorant than I am (that would be almost everyone).
I'm not intimidated by pulling the head and replacing the gasket after splitting the whole blasted thing in two a week ago. I'd take the head to my machinist buddy and have him check it for flat too, if I should. The "spare parts" kit has a new head gasket. I don't want to do it, of course, but if I should I will.
There it is, to the best of my ability to describe it. What do you guys have to offer in the way of guidance? I need this thing running right and dependably. Anything else I should check or look at? I'm limited on diagnostic equipment - no compression tester for diesels, no leak-down tester for the radiator or combustion chambers, no combustion gas detector, etc; just wrenches and stubbornness.
I picked up a new Delco 12Si alternator for it that I'll get around to soon, I hope. Still need to get a new fuse block first - I ain't impressed with the Chinese one at all. That problem with the regulator fuse has caused me too many headaches and I gotta fix all that crap right and be done with it so I can believe my gauges and not screw something else up.
Thanks in advance for your input! That痴 if you're still actually awake after trying to read this magnum opus.
Rich
/ Overheating problem #2
Fair conclusion, especially considering that conventional wisdom recommends retorquing the head gasket and setting valve lash at 50 hours. After all that overheating, just hope all you find is a bad gasket.
The bubbles you're observing through the filler neck by the way, are most typically caused by exhaust gases leaking into the cooling system. And the blue-white observation suggests oil (blue) and water (white) getting into the exhaust manifold.
//greg//
/ Overheating problem #3
I understand what you are saying regarding the water loss. My 30hp Siromer went fine for the first 2 years then started to overheat regularly, the electrical gauges being totally crap were my first thought (they have since broken and been replaced with mechanicals) but I also suffered water loss out the overflow. I changed the radiator cap, no change. Removed the thermostat, no change. I had been regularly blowing seeds and stuff out of the radiator and thought it was OK but removed it anyway and washed all the fins though and flushed it out, finally it stopped over heating (except when flail mowing in 30 degrees C which I forgive it)
Before pulling the head etc. remove the rad, clean inside and out with a low pressure hose and refit. Its worth a try as it's simple to do and there is no parts expense!!
/ Overheating problem #4
Carry on Rich, your literary competency is very refreshing. :thumbsup:
You should also consider installing a coolant recovery cannister. This will assist you in determining if you are loosing coolant through expansion only (they are also a great aid in de-aerating the cooling system). The "carbonation" you are witnessing could also be from cavitation around cylinder liners or air entrapment from plugged or restricted coolant passages.
When you capped off the radiator with your hand did you remember to plug the overflow also? (just checking :D).
Thanks, Bob. Uhhhhhh...no. I didn't think to close off the overflow tube, blast it. That was dumb. Have to try that again the right way, huh?
The coolant recovery canister is on the way. I'll get it put on if I can find a spot for it. It may be a mite too big to fit comfortably, though. Won't know until it gets here. For a temporary check of the concept I could just use a 20 oz Dasani water bottle and a hose clamp, I suppose. Nice and clear, too. I have an inexhaustible supply of them, too - should have thought of that before I bought one. Too quickly I get older, too slowly I get smarter.
I doubt that I have any blocked coolant passages, but it is possible. Only 100 hrs on the thing and I did flush it all out when new and again when it overheated. Doesn't cost anything but time to do it again, though. Might be core sand or someone's stale won ton in there somewhere.
What causes cavitation around cylinder liners? Is that something I can affect, or is it one of those shrug your shoulders and hope things? Over my pay grade, I think, but it never hurts to learn something new.
Thanks for keeping me straight here.
Rich
/ Overheating problem #6
That will work just fine for a test.
Yes. I have had to do re-works and found gasket fragments, rags, tools, etc. left in engines.
:laughing: If you haven't had the engine apart, then another shouldn't be necessary at this time.
Turbulent liquid over rough surfaces at velocity, hot spots on liners due to casting sand impingement (which creates the rough surfaces), casting sand or debris build up creating eddy currents and voids around liners (strong arguments for coolant filters and coolant with SCA's), and the list goes on...
12345
/ Overheating problem #7
yes, I went nuts and did all that stuff too. alot of time and money replacing with new parts. One fellow on this site said " if you do a lot of mowing, the dust (read pollen) will coat the fins off the rad. ". Well you could shine a light right through, so I ignored the advice. Wrong!! those fins remind me of an air conditioners, light and closely spaced. long story short (to late) brought it steaming back to the shop and used the water hose to flush both front and rear, and yes it quit overheating. so ever time it overheats back for a douche. so as my dad used to say, start with the simple and work back towards the expensive.
Thanks Terry, that's a good point to keep in mind about most issues.
Rich
/ Overheating problem #9
You know for a buck or two, you can buy thin room air conditioner filters, They may not stop all of the dirt, but they will catch a good majority of it. You can either replace them or just clean them once in a while. You can hold them in place with cheap plastic clips from Harbor Freight. ITs easier than blowing out the Radiator.:thumbsup:
Mgrove
/ Overheating problem #10
FWIW, I use washable furnace filter material. Inexpensive, easily cut to fit with a scissors, available at most WalMarts. Stands up will to either water hose or air compressor. It's a full inch thick, so I don't even need to fasten it. And is big enough that I can cut two tractor filters from one furnace filter.The air cleaner housing bracket holds it in place nicely. Pulls right out for cleaning, and it's tough stuff. Have had the same pieces on both my tractors for several years now, neither show signs of needing replacement yet.
//greg//
/ Overheating problem #11
Same thing happened to me on my 224. But the crap was really packed in the rad like paper mache. I read here not to power wash it, but blowing with air was ineffective, you cant get a blower nozzle where you need it to do the trick. The rad "guard" the 224 came with doesn't do much to catch any chaff at all.
So, I just soaked the whole thing with a hose and let it sit. The crap softened up enough so I could just hit the front of the rad with the garden hose, then checked with a flashlight. That got all the stuff out and from then on no overheating.
I also use the blue filter stuff, it really works well. Havent had a mess in the rad since.
I guess maybe I'll look into the blue filter stuff. May be a bit harder to find in a place where absolutely no one, but no one, has a furnace. :) They might use it in air conditioning systems and there may be a few people with AC systems around the island - I'll the local HVAC places and see if they carry it. I know Kmart doesn't.
If it saves on time cleaning the radiator fins then it's definitely worth it.
Rich
Thanks for the link, Greg. If I can't find something locally I'll look into that.
/ Overheating problem #15
I use 2 layers of metal/aluminum window screen wrapped around the original slip in guard plate that fits into the grooves in the front of the radiator. Windo screen ought to be readilly available where you are at... The 2 layers are enough to catch most all the airborne debris that would clog the radiator passages. It is still thin enough to allow the plate to slip down in the grooves. It also dosn't require anything special to clean. Just take it out and drop it on the ground and most all the debris falls clear. A little swing backwards thru the air(reversed airflow thru the screen) blows most all the remaining debris out of the screen, then it is back into the slot and back to work. When brushmowing, I have to clean mine about every 2 hours or so, unless it is wet with less flying debris. I am pretty habitual about scanning the gauges, and as soon as it starts to creep over 80C, I bring it back to idle and go pull the screen filter. Cottonwood seed is the worst, it covers that screen like a polar fleece coat:) The screen also dosn't wear out. I have been using the same piece for several years now, since July of 05.
I made a blowgun nozzle out of a piece of aluminum arrow shafting. The nock end of this shafting is swaged to a rounded point to allow the plastic nock to be glued on. I remove the plastic nock with a bic lighter and pliars, then drill a 1/8" diameter hole in the side of the shaft right where the taper begins. This pipe I attach to a regular airhose blowgun valve. The arrow shaft I chose could be press fit over an existing 3" straight blowpipe. On my radiator, the fan shroud is fitted so there are 2 small openings just large enough for the long pipe to fit, at the top rear corners of the radiator. If yours does not have these, you could add openings quite easilly. With the drilled hole, the air exits at a 90 degree angle to the pipe. Between the 2 holes at the top rear of the radiator, I can reach 99% of the rear face of the radiator to blow dust and debris out thru the front. The rounded point on the arrow shaft keeps it from hanging up on anything or bending fins. Mine works great, and I do this type cleaning every now and then to remove the fine dust that will pass thru the screen.
That's a good idea, Ron. I already modified the track that holds the chaff screen on my tractor since it was impossible to pull the screen past the air duct from the air cleaner. It now is retained with a small neodymium magnet and can be pulled instantly. I'm gong to try the window screen wrap as a first effort, since i already have a roll of nylon screen on hand. I think that may be all I need with the type of chaff I get mowing our local guinea grass. If not, I can always find some filter material. Thanks!
Rich
/ Overheating problem #17
Wow, I just posted an overheat problem with my foton 254 not too long ago and there is alot of cheap good ideas here. I like the furnace filter and even window screen idea to save the rad getting dirty. I think I even have window screen in the garage to try once I clean out the rad. I do alot of mowing so this is more than likely the problem, thanks everyone!!
