Adustment for GC headlights??
/ Adustment for GC headlights?? #1
Wacky
West Virginia
2010 GC2610
Is there no way to adjust the headlights on the GC's?? I cannot figure it out. Must be some way, right?:confused:
/ Adustment for GC headlights?? #2
On the GC 2300 that I have there's noway to adjust the lights.Its one plastic unit that fits into the cutout in the hood and just bolts into place.All you do is change bulbs when they burn out.Off course if you happen to break the lens you have to buy a complete unit and bolt it in.Larry
/ Adustment for GC headlights?? #3
A few well placed 1/4" flat washers is what I used...helped a lot. I didn't see any other way to do it but to shim it as it is a one piece assembly on mine.
Good idea. I will try that. The reason I ask is that I noticed that it is just a little low for my use. Especially the left one, they may have one side lower to give a more "field of vision" if you will.
I could only imagine the $$!
/ Adustment for GC headlights?? #8
Just a little low. I wish I had halogen like you Kubota boys:thumbsup:!
If you need to use your lights that often you can always buy a set of halogen driving lights and mount them some place on your tractor.I have a set mounted on my winter cab in case I need to blow snow at night.They make some pretty neat looking lights that'll fit in perfect with your tractor.Larry
Schuler Feed Wagon (A66408)
Schuler Feed Wagon...
Worksaver 3 Point Post Hole Digger (A65640)
Worksaver 3 Point...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
Troy-Bilt Pony Riding Mower (A65579)
Troy-Bilt Pony...
